Click Here
Closed Thread
Old 02-11-2009, 08:37 PM   #2001 (permalink)
jrotax101's Avatar
Robert
Owner = speedracervroom if you want more info PM him.
front offset is extremely weak..
back should be an inch higher, with 5mm less offset to pull it off, rather than tucking the wheel..
they stretch tires for a reason.. lol
jrotax101 is offline
Old 02-12-2009, 12:07 PM   #2002 (permalink)
trystar's Avatar
i know that 18 x 8.5 + 45mm fits but does anyone have pictures of what it looks like on the car?
trystar is offline
Old 02-12-2009, 01:03 PM   #2003 (permalink)
dt07Si's Avatar
Dave
Check out the username: qwerty
He has Advan RZ's in that spec with I believe 225/40/19 tires.
dt07Si is offline
Old 02-12-2009, 01:19 PM   #2004 (permalink)
jrotax101's Avatar
Robert
i hope he's not running 225/40/19 on 18" wheels
Old 02-12-2009, 02:47 PM   #2005 (permalink)
i haz teh BBQ!
OMGWTFBBQIMDEREK's Avatar
Derek
He's so JDM he might be. You don't know what people will do for "JDM tyte ish yo! u kno wuh im sayinz?"
٩๏̯͡๏)۶
OMGWTFBBQIMDEREK is offline
Old 02-13-2009, 12:15 AM   #2006 (permalink)
OK, this is what I'm buying...Enkei RPf1 17x8 35 offset with 235/40/17. FG2 with Pro kit.
Any rub issues???
armandokn3 is offline
Old 02-13-2009, 12:37 AM   #2007 (permalink)
dt07Si's Avatar
Dave
Ha ha you guys got me...
Any rub issues???
With the right camber specs and a pro kit you should be fine.
dt07Si is offline
Old 02-13-2009, 01:32 AM   #2008 (permalink)
rwc
rwc's Avatar
Randy
lmaoooooo!!!
look at that m4d tyt3 -5 deg camber y0! and those awesome 205 series tires on wheels that are prob 8.5" wide aahahahahaha
can you say understeer like a mofo?
-RWC8THC
rwc is offline
Old 02-13-2009, 01:42 AM   #2009 (permalink)
hoanger's Avatar
www.jayhoang.blogspot.com
Hey, don't hate.
This guy has a sick set up. He's not even that bad compared to the VW guys.
He's got balls to run it like that and be hella flush. I think it's too sick.. one of my favourite set ups on here
hoanger is offline
Old 02-13-2009, 01:46 AM   #2010 (permalink)
rwc
rwc's Avatar
Randy
heres one that works
this is my 18x7.5 +37, with 225/40/18 tires, and hfp drop
its flush, it looks good, my tires actually fit, i rub very little, and i also have 0 camber.
i could probably get rid of the rubbing altogether, but i dont like uneven treadwear and i also like to drift it a lil bit(as much a fwd car can anyway) if i wanted to go a lil bit lower, i could prob add about 1-1.5 deg of negative camber in the back and still be fine.
rwc is offline
Old 02-13-2009, 01:50 AM   #2011 (permalink)
hoanger's Avatar
That looks great too.
The only difference is that he's tucking and that's what makes it wicked. Everyone has different tastes.
hoanger is offline
Old 02-13-2009, 02:00 AM   #2012 (permalink)
rwc
rwc's Avatar
Randy
if looks are your only concern then by all means do it... i'd just hate to see someone get hurt from running an unsafe setup because they saw it on here and thought it "looked cool"..
for me personally, i drive my car daily. i need something safe and reliable. hence why i run what i do.
rwc is offline
Old 02-13-2009, 02:02 AM   #2013 (permalink)
dt07Si's Avatar
Dave
Originally Posted by hoanger View Post
Hey, don't hate.
I agree he has balls, and your right he's not as bad as most VW guys. I do like to see people push the limits, however I'd rather see someone push the limits with a reverse stagger on a FWD car and have it not only look good but handle much better then stock, not much worse.
Perfect example...
Or even your car Jason once you get your new wheels on! And hopefully mine soon enough
[img ]http://www.quickteck.net/rwc/020909/IMG_1776.jpg[/img]
Not a bad setup by any means, and certainly handles much better then speedracervrooms car and probably better then stock. However it's really only flush because you are running and OEM aligment. And sure negative camber will cause some inner tire wear, but with your toe zero'd out it's very minimal, and with a non staggered wheel setup rotating your wheels can help minimize it even more.
If i were you i would atleast dial in -1.5 to -1.75 degrees up front and about -1.0 out back (which is stock). It will improve your handling, and eliminate any rubbing you may have.
dt07Si is offline
Old 02-13-2009, 02:04 AM   #2014 (permalink)
24boosted's Avatar
I think you want a bit of camber, even stock specs have some camber. I'm running a similar setup 18x7.5 +32 on 225/40/18s as well.
24boosted is offline
Old 02-13-2009, 02:06 AM   #2015 (permalink)
rwc
rwc's Avatar
Randy
i actually do have plans of doing somehting similar to that when/if i get my new suspension which will put me about a half inch lower. i will probably be using -1.5 in front and -1 in back
rwc is offline
Old 02-13-2009, 02:06 AM   #2016 (permalink)
hoanger's Avatar
Dave, FEEL's car was my inspiration for the FWD stagger! They were able to fit 255's up fronts with a wider wheel as well. I didn't have THAT much balls haha
I can't wait! I hate winter
hoanger is offline
Old 02-13-2009, 02:11 AM   #2017 (permalink)
rwc
rwc's Avatar
Randy
deleted lol
yeah i like that reverse stagger setup.. not a bad idea
rwc is offline
Old 02-13-2009, 02:22 AM   #2018 (permalink)
dt07Si's Avatar
Dave
There's a chance I might be running something VERY similar to the Feel's FD2 this season
Jason, where did you see the tire specs on the Feel's car? I have read the front wheels are 18x9+35's but I really wonder if that's true. They look 9.5's to me, but I might be able to verify what they are this weekend.
dt07Si is offline
Old 02-13-2009, 06:20 AM   #2019 (permalink)
nerdrum's Avatar
Those are FEELs overfenders as well, upfront thats probably 18x9.5 +18/22.
nerdrum is offline
Old 02-13-2009, 06:27 AM   #2020 (permalink)
xheartcore_boyx's Avatar
Addy
You rub?!? i got the exact same fitment and drop but with 8" wide instead of 7.5" and i have zero rubbing!
well i got camber adjustments (1-1.5) but i still can't see it rubbing even without that.. got any side shots?
Looks real good though
xheartcore_boyx is online now
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
18 This thread Refback 01-14-2008 01:34 PM
18 This thread Refback 01-14-2008 10:57 AM
18 This thread Refback 01-14-2008 09:21 AM
18 This thread Refback 01-14-2008 09:17 AM
Wheel Fitment Recipe - wheel offsets that work - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 06:51 PM
Wheel fitment... Now maybe a problem DumbasSi Wheel And Tire Upgrades 26 04-27-2006 07:10 PM
Wheel offsets? Jake Wheel And Tire Upgrades 1 01-06-2006 01:35 PM
