Click Here
Closed Thread
Old 03-26-2007, 04:20 PM   #181 (permalink)
trystar's Avatar
subscribed for future wheels.
trystar is offline
Old 03-27-2007, 04:02 PM   #182 (permalink)
Razor4ever's Avatar
Originally Posted by exhaust_note
yeah they will fit.. i hate those lug nuts though. worst things ever designed.
what does the 48mm offset mean? Cuz Im only concerned about this.
Razor4ever is offline
Old 04-04-2007, 02:39 PM   #183 (permalink)
Originally Posted by RODSCIVIC
Sedan: 17X7 +42 225/45 lowered on Eibach Pro Kit is good to go with plenty of room.
I used this configuration, and I'm getting a bit of rubbing on the front tires with the plastic clip inside the upper side of the fender.
Also - my car is not lowered.
shiftology is offline
Old 04-07-2007, 01:59 AM   #184 (permalink)
what is the difference b/t 205/45-17 and 225/45-17?
irichard is offline
Old 04-07-2007, 06:56 PM   #185 (permalink)
ok i've tried to make sense of this thread but i'm looking for an easy answer
I have a 06 EX sedan, stock ride hieght, no plans to drop it, will 18x7 with en ET42 work with 225/40/18s?
i cannot have any rubbing at all
janaka is offline
Old 04-10-2007, 05:39 PM   #186 (permalink)
Si4Life's Avatar
Whos High Pitch?
edited....not paying attention
Si4Life is offline
Old 04-11-2007, 01:36 PM   #187 (permalink)
no one knows?
can i assume that since a 17x7 with a 40et will work with proper tires that the 18x7 would then also work?
not one single 8th gen owner who has posted in this thread has posted an 18x7 rim so i'm looking for confirmation before i pull the trigger on this deal.
any input is much appreciated
jay
janaka is offline
Old 04-13-2007, 12:46 AM   #188 (permalink)
FG2z_K's Avatar
Will 18x8.5 30mm offset work on the stock coupe si? tires will b 245/40R-18
FG2z_K is offline
Old 04-13-2007, 12:53 AM   #189 (permalink)
Tim
Tim's Avatar
Originally Posted by janaka
no one knows?
jay
Probably. That's the size of the HFP wheels.
Tim is offline
Old 04-13-2007, 12:54 AM   #190 (permalink)
Tim
Tim's Avatar
I don't know that anyone's run tires that wide or an offset that low. It seems doubtful without some modification.
Tim is offline
Old 04-13-2007, 02:15 AM   #191 (permalink)
aki
aki's Avatar
Semi-Si Sedan Hater
Correct me if I'm wrong, but aren't you ok as long as the inner clearance (aka backspace) remains the same?
So a 8" width w/ 32mm offset would fit, as it has the same clearance (146mm) as a 7" width w/ a 45mm offset.
Wondering because if I get different rims I'd want a deeper rim look (aka BMW M3).
aki is offline
Old 04-13-2007, 02:54 PM   #192 (permalink)
esx005's Avatar
jeremy
i have 17x7.5 w/40offset and other than the camber in the rear it works.just thought i would add to te list.i am dropped1.5,i believe,and the only rub i have is if i bottom out. it rubs a little in one spot but doesn't look like it will rub forever just the first couple of times
esx005 is offline
Old 04-14-2007, 05:01 PM   #193 (permalink)
COMplex's Avatar
got e85?
I want to see some lower offsets...
COMplex is offline
Old 04-14-2007, 05:15 PM   #194 (permalink)
esx005's Avatar
jeremy
how much lower i have a 40 offset
esx005 is offline
Old 04-14-2007, 05:25 PM   #195 (permalink)
COMplex's Avatar
got e85?
Lower than 35
COMplex is offline
Old 04-14-2007, 09:30 PM   #196 (permalink)
http://www.yqwheel.com/products.htm
i'm looking into getting some wheels from this site (long story, but they're free for me)
2nd page
3rd ones down,
18x7.5" 42mm et,
PCD 100-120 - i fully appreciate that we're 114.3 - so whats up with these wheels - is it that one set of 5 holes fit 100, the other 5 fit 120 - meaning htat they won't work for my car?
thanks in advnace
ianwells100 is offline
Old 04-14-2007, 09:34 PM   #197 (permalink)
Tim
Tim's Avatar
You're right. Those are made for other cars. Won't fit.
Tim is offline
Old 04-14-2007, 09:42 PM   #198 (permalink)
Louder than 4 F404-GE-400
Sirbelch's Avatar
Paul
I got 17x8 +45 offset with a 235/40/17 tire and its lowered 1.75in ish on my Si and i and i have no problems. I still have about and inch of space between the top the the tire and the edge of the fender.
Sirbelch is offline
Old 04-14-2007, 09:51 PM   #199 (permalink)
Tim
Tim's Avatar
coupe or sedan?
Tim is offline
Old 04-14-2007, 11:09 PM   #200 (permalink)
Si4Life's Avatar
Whos High Pitch?
this guy guy posted elsewhere today that he does rub.......whats the deal, do you rub or not?
Si4Life is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
18 This thread Refback 01-14-2008 01:34 PM
18 This thread Refback 01-14-2008 10:57 AM
18 This thread Refback 01-14-2008 09:21 AM
18 This thread Refback 01-14-2008 09:17 AM
Wheel Fitment Recipe - wheel offsets that work - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 06:51 PM
Wheel fitment... Now maybe a problem DumbasSi Wheel And Tire Upgrades 26 04-27-2006 07:10 PM
Wheel offsets? Jake Wheel And Tire Upgrades 1 01-06-2006 01:35 PM
