Click Here
Old 12-13-2007, 08:39 AM   #1 (permalink)
tire rotation
how much does it cost to rotate your tires
07civicex20 is offline
Old 12-13-2007, 08:50 AM   #2 (permalink)
I think most places charge like $20.00-$40.00. I would rather do it myself on a weekend. It will take you about 30 minutes. Jack the car up, replace the front tire with the spare, then swap the back with the front, and then swap that one with the spare. (assuming you only have the one jack). It seems like a lot of work, but you can also wash the insides of the rims while they are off the car if you're a clean freak I rotate them every other oil change.
Jayhawker is offline
Old 12-13-2007, 11:53 AM   #3 (permalink)
HondaScott's Avatar
Scott Varnhagen
I'm confused? Are you talking about swapping diagonally, because I think the stock tires are directional.
Why not just jack th side of the car up high enough that you can remove both wheels on that side and swap them?
HondaScott is offline
Old 12-13-2007, 02:01 PM   #4 (permalink)
drahgon's Avatar
Daryl
I don't know about the optional performance tires, but the stock all seasons aren't directional. That being said, I don't bother with the diagonal rotation either, just front to back.
drahgon is online now
Old 12-13-2007, 02:29 PM   #5 (permalink)
eugenekim.net's Avatar
captain obvious
it's super easy and can be done with the tools provided to you in your trunk. on the right side, swap the front and rear tire. on the left side, swap the front and rear tire. done.
eugenekim.net is online now
Old 12-13-2007, 02:34 PM   #6 (permalink)
Supreme Pizza!
Izzy's Avatar
Don't you want to flip around the rear tires from left to right as well?
Izzy is offline
Old 12-13-2007, 02:38 PM   #7 (permalink)
captain obvious
depending on if they're directional or non-directional.
Old 12-14-2007, 07:59 AM   #8 (permalink)
8thcivic Sponsor
Spencer@tirerack's Avatar
check this out: Tire Tech - Tire Rotation
Spencer@tirerack.com 1-877-522-8473 x690
*Remember to reference my name on Tirerack online orders*
Use the link below to support the forum!
http://www.tirerack.com/winter/index.jsp
Spencer@tirerack is offline
Tires, Camber, Caster, Toe!!! Highrev1 Suspension and Brakes 23 06-24-2008 10:08 AM
*8thCivic Tire Help 101* CrackThatTec45 Wheel And Tire Upgrades 49 06-15-2008 10:58 PM
Tire pressure check method?? MADDOGSI Mechanical Problems & Technical Chat 19 02-19-2007 02:14 AM
Tire Rotation on Civic EX? Civic2006 Civic Coupe And Sedan 11 01-08-2007 01:22 PM
Maintenance Minder & Tire Rotation kish-81 Mechanical Problems & Technical Chat 14 10-21-2006 11:54 AM
