it says on the list of wheels that will work that a 20 x 8.5(35mm offset) is good with a 1" drop..i want to run 19 x 8.5 with either a 225/35/19 or 235/35/19 tire. im also going to drop the car with the H-tech springs from Tein..please help??? thanks
It will work with right modifications (proper offset) and if that is the look you want, go for it. Just remember, the ride will suck. Tires will be like solid rubber and will feel every imperfection in the road. Plus, if you hit a pothole at a high speed, most likely you will damage your rim.
#12 (permalink) |
Resident Si Sedan Hater
Eh, I wouldn't go lower than 42 offset for 8.5 width wheels. 19x8.5 w/ 225, 45 offset is the safest. With 45 offset you can probably fit 235s w/o rolling. If you go with 38 offset or below it's pretty much guaranteed that you'll need to roll fenders.
| 2007 Honda Fit | webby | Garage | 27 | 07-19-2008 12:48 PM |
| Tires, Camber, Caster, Toe!!! | Highrev1 | Suspension and Brakes | 23 | 06-24-2008 10:08 AM |
| Rear wheel tapping noise | Grimey | Mechanical Problems & Technical Chat | 11 | 06-12-2008 07:16 PM |
| HFP R5 wheel or TSX? confusion reigns...HELP! | bryman10 | Wheel And Tire Upgrades | 5 | 10-06-2007 08:11 PM |
