Click Here
Old 04-20-2006, 10:25 PM   #1 (permalink)
Chitown SI's Avatar
Exclamation Check your lug nuts!!!!
FYI: CHECK YOUR LUG NUTS!!! As many of you already know, when installing aluminum wheels. It is good practice to re-tighten the lugs after driving on them for 50 miles after the initial install. Most auto manufacturers tighten them beyond tight. So this isn't really an issue. Well today, I was installing my new 18 inch O.Z. F1 corsas. When I went to take the OEM lugs off, I expected them to be very tight (from past experience). But they were not. My 10 year old could have taken them off!!! So please check your lugs ASAP for your safety and everyone else.
Chitown SI is offline
Old 04-20-2006, 10:28 PM   #2 (permalink)
Acorn!
2fast4u2's Avatar
8thcivic.com member #15
Thanks for the heads up.
2fast4u2 is online now
Old 04-20-2006, 11:21 PM   #3 (permalink)
Kurt's Avatar
checking my nuts as we speak
Kurt is offline
Old 04-20-2006, 11:36 PM   #4 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Mine are pretty loose right now. I'll tighten them up later. I'll check my lug nuts after that.
Next NorCal Meet - North Bay
- 8 t h g e n u s e r -
8thgenuser is offline
Old 04-21-2006, 02:16 AM   #5 (permalink)
Loose nuts sound like a condition that should be checked. Maybe Gold Bond will help. It certainly tightened mine.
As for my lug nuts........
skittleslegend is offline
Old 04-21-2006, 10:21 AM   #6 (permalink)
Kurt's Avatar
gold bond is the greatest, i just loaded up for the day
Kurt is offline
Old 04-21-2006, 01:37 PM   #7 (permalink)
amdhunter's Avatar
I just checked mine and its all wet and sticky...
amdhunter is offline
Old 04-21-2006, 02:34 PM   #8 (permalink)
wow. are we all 12 here? :)
thanks for the warning though!
liuh is offline
Old 04-21-2006, 03:15 PM   #9 (permalink)
jaywo's Avatar
I had the opposite problem... I used my impact wrench on them to get them off and one i had to go to as high PSI as i could and let sit there trying to turn for like a minute or two... That would be fun to try and take off if i had a flat... when an impact wrench can barely do it... Ohwell fixed now...
jaywo is offline
Old 04-21-2006, 06:14 PM   #10 (permalink)
Crazy Yellow Puppet
CameronJr9's Avatar
Back and Forth Forever
Sometimes if you actually tighten the lug for a split second, then try to loosen it, that'll help. I had to do that with my '94 when I was changing my brakes.
CameronJr9 is offline
Old 04-22-2006, 01:10 PM   #11 (permalink)
k20z3Vo's Avatar
Mine are kinda crushed as we speak...
R.I.P. 06' Civic SI 07/16/07
http://www.8thcivic.com/forums/showt...b135cebbf8462&
Slammed EG6....
k20z3Vo is offline
Old 04-22-2006, 03:32 PM   #12 (permalink)
Scourge's Avatar
Or get a torque wrench and torque them to spec. I think I've got mine at 90 ft-lbs? I can't remember. Not too tight and not too loose.
Scourge is offline
CHECK YOUR CAR, if it gets towed! Rommy Garage 15 05-10-2006 02:38 AM
Honda Locking Lug Nuts Tennisjon2002 Inside and Out 3 04-20-2006 04:38 PM
Locking Wheel Nuts? jaywo Wheel And Tire Upgrades 4 04-07-2006 04:14 PM
Anyone got a carfax account? Kabs Water Cooler 15 12-23-2005 12:02 AM
Chrome lug Nuts eric29 Wheel And Tire Upgrades 2 12-01-2005 06:56 AM
