#102 (permalink) | |
You should have no problem w/ that tire set up with the HFP suspension. I'm currently running 215/45-16 for autox and would like to move on to 225 or 235 in the near future. A sidewall of 50 seems a bit long. I'd go with 45 (or even 40 if they make them for 16s... which i doubt). I prefer quicker steering response and less lateral lean. |
#103 (permalink) |
im so clue less on the offset thing here my tires are 225/40 R18 95H
the wheels i have are g-racing wheels 18's got them from a family friend does not seem to rub when i turn wheel both ways seems to be good clearance.. So on these wheels how do i find out what the off set is and the factory wheel offset i have a 2007 Honda Civic Ex Sedan any help please car looks sweet with them but dont wnat no performace hit or any issues thanks 8th! fty got this from discount tires Tire 1 / Tire 2 205/55 r-16 (stock) /255/40 R-18 Tire 1 / Tire l2 / diffrence sidewall height: 4.44 / 3.54 / -.90 section Width : 8.07 / 8.86 / .79 overall diameter: 24.88 / 25.09 / .21 circumference: 78.16 / 78.81 / .65 Revs Per Mile: 831.01 / 829.02 / -6.99 if your speedometer reads 65 you're going aproximately 65.55 so is this right and is it ok ?? Last edited by Rican768; 06-13-2007 at 02:18 PM. |
#108 (permalink) |
I have TSX rims and General Exclaim 215/45/17 on my sedan and they look sweet from the side, but in front or behind the car you can't even see them! The tires look so skinny. I'm a tad disappointed from rear or front angles. What are my options to make the wheels a little wider? Can I put 225/45/17 tires on the TSX wheels? Can I add a spacer to move them out a tad?
#111 (permalink) | |
Adding these spacers (will have to see how pricey) won't affect my lugs, or anything? I saw some with SI rims and spacers speak of lug issues where the wheel loosened up over time? I just want the tire to be as close or right at the middle edge (at least) of the fender so you see the wheel and not the inside plastic of the fender. (update; Ah, these spacers have their own lugs) |
#112 (permalink) |
I know my chances of getting a response are slim to none, as I should be doing my own homework, but i need some help here...
I ordered 17's with a 45 offset. Shopping for tires now. Would 225/45 work ok ? Also, how would they fit on the stock rims? |
#113 (permalink) | |
#114 (permalink) | |
for example.... stock: 17x7 w/ 215/45/17 = 24.6" overall wider: 17x7.5 w/ 225/45/17 = 25" overall +size: 18x7.5 w/ 225/40/18 = 25.1" overall use this site to comapre sizes and offeset..http://www.rims-n-tires.com/rt_specs.jsp |
#119 (permalink) |
16 inch on Si
I was just at the Honda dealer. They had a set of 16 civic steel wheels off of a 07 civic lx with tires for sale. Had them put on my 07 Si and the caliper had less than 1/4 inch clearance and the gap around the caliper was real close too. After looking at it they recommended not using 16's on the Si.
Hope this helps Jack |
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6175-tire-sizes-ok-use.html
| 18 | This thread | Refback | 01-15-2008 08:28 PM | |
| 18 | This thread | Refback | 01-14-2008 12:31 PM | |
| 18 | This thread | Refback | 01-14-2008 09:49 AM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Post your wheels + tire setup | Tate | Wheel And Tire Upgrades | 33 | 09-04-2007 10:51 PM |
| 06 Si Tires | Tennisjon2002 | Wheel And Tire Upgrades | 23 | 08-17-2006 09:39 PM |
| Anyone Know the Speaker Sizes for the New 2006 Civic SI??? | leekejeun | I.C.E., Electrical, Security, & Navigation | 26 | 04-01-2006 04:55 PM |
| A better tire reccomendation? | Silver06 | Wheel And Tire Upgrades | 7 | 12-15-2005 06:00 PM |
| help with bulbs sizes??? | youngxlos | Civic SI | 6 | 11-06-2005 10:56 AM |
