Click Here
Old 10-01-2007, 10:28 PM   #1 (permalink)
18x8.5 fitment
Looking at a 18x8.5 wheel with a 48mm offset 5x114.3 bolt - will this fit the si? recommended tire size?
Thanks - and sorry if this has been asked - I tried searching...
2006sinavi is offline
Old 10-02-2007, 09:24 AM   #2 (permalink)
Brett
18X8.5 45mm offset 235/35-18 will fit, I'm not sure how to do the math for +3 offset to make 48 though?
Blackł is offline
Old 10-02-2007, 09:47 AM   #3 (permalink)
NA06Si's Avatar
Christian
I installed my 18X8.5 (45mm offset) Gram Lights yesterday with 225/40 rubber and no fitment issues. I've been told by several folks (including Tirerack) that 235 rubber would require the wheel well lip to be rolled.
NA06Si is offline
Old 10-02-2007, 10:22 AM   #4 (permalink)
8thcivic Sponsor
Z1 Performance's Avatar
225/40/18 is the better fitment
Jonathan - www.z1auto.com - 631-863-3820
GT-SPEC FENDER BRACE PRE-ORDER!
http://www.8thcivic.com/forums/z1-pe...-preorder.html
Check out our BLOG for:
-Customer rides
-New products
-Original articles
Z1 Performance is offline
Old 10-02-2007, 05:37 PM   #5 (permalink)
Brett
Sorry about that, I meant to type 225 - on a side note just an fyi
when the speedo says 65 mph with those 18"'s you'll actually be going 63.9 mph so thats 1.1 mph off - and thats a good thing because you'll be less likely to get a ticket!
Blackł is offline
Old 10-02-2007, 07:21 PM   #6 (permalink)
Thanks guys - what about the 48mm offset? Is that ok?
Old 10-03-2007, 05:33 PM   #7 (permalink)
I'm running 215-35-19's on a 8.5 width minor stretch the offset was a 40mm
next level is offline
Old 10-04-2007, 03:56 AM   #8 (permalink)
Chris
i had a wheel with a 45mm offset. i am lowered on tein basics. my tire rubbed just barely enough that i got a 3mm spacer. now thats how i run my setup.
streetmachine02 is offline
Old 10-04-2007, 04:02 AM   #9 (permalink)
HONDACARE's Avatar
Gabe
several folks and tire rack are wrong. i run 235's w/no rubbing
HONDACARE is online now
Old 10-04-2007, 04:35 PM   #10 (permalink)
AznSupastar's Avatar
2007 Taffeta White Si Coupe
how low is ur car? would ride height affect the tire / tein coil rubbing (aside from the fender rub if any)? any pix of ur ride, i'm thinking of doing similar setup.
AznSupastar is offline
Old 10-05-2007, 09:46 AM   #11 (permalink)
8thcivic Sponsor
235's will rub on a car with 18x8.5 wheels that is lowered 1.5 inches or more. It may be possible to dial most of it out with negative camber.
A 235mm tire will also rub on the Tein coilover body because it is noticably thicker than the OEM shock body. You would want to run a small spacer to clear the coilover but that would mean even more rubbing on the outer fender/liner.
-Customer rides
-New products
-Original articles
fitment question phantom-civic Civic Coupe And Sedan 1 04-20-2007 12:26 PM
18x8.5 45mm offset? ooooweeitzamy Wheel And Tire Upgrades 4 04-04-2007 05:14 PM
fitment question, 18x8.5 volk racing kyeguy82 Wheel And Tire Upgrades 18 01-05-2007 04:50 PM
18x8.5 Showtime Wheel And Tire Upgrades 16 05-12-2006 11:13 PM
