Click Here
Old 02-17-2008, 04:36 PM   #41 (permalink)
PrEgO CaNe's Avatar
Brendan
i know that we aren't allowed to cross rotate tires. they've done studies that it weakens the tire and leaves them more likely to have a blow out. we rotate the tires front to back and you always mount the new tires on the rear! unlike many people think cause there vehicle is a front wheel drive the best tires should be on the front.
PrEgO CaNe is offline
Old 02-20-2008, 01:35 AM   #42 (permalink)
furryferret7888's Avatar
kris
what about the 'treadwear' on a tire...like 300 or 430?? what is better...is it like golf or basketball??
furryferret7888 is offline
Old 02-20-2008, 08:41 AM   #43 (permalink)
PrEgO CaNe's Avatar
Brendan
the higher the tread wear is the longer the tire will last. every company is different so you can't really compare company to company to much. winter tires usually don't have a tread wear rating because the rubber is too soft. basically if a tire has a tread wear rating of a 100 and another tire has a tread wear of 400. the 400 tire will last 4 x as long as the 100 tread wear tire! don't ask me how long 100 should last you cause every tire company is different. if your trying to compare tires, try and use two names that are made by the same company (ex. BF Goodrich and Michelin)
Old 02-20-2008, 12:25 PM   #44 (permalink)
kris
awseome...so its like basketball...yessss
Old 05-04-2008, 11:55 PM   #45 (permalink)
emile's Avatar
Emile
what about temp rating?
emile is offline
Old 05-05-2008, 07:07 AM   #46 (permalink)
PrEgO CaNe's Avatar
Brendan
here this might help a bit " Temperature ratings run from A to B to C, with C being the minimum allowable for passenger car tires. The ratings correspond to a tire's ability to dissipate heat under load; tires with lower ratings are more prone to heat-induced failure, especially if driven at high speeds (or when overloaded). As with traction ratings, never buy a tire with a temperature rating that's less than specified for your vehicle." Everything you need to know about tires - CNN.com
Old 05-05-2008, 05:57 PM   #47 (permalink)
emile's Avatar
Emile
thanks a lot man. so A rated tires would work for the fa5 no?
emile is offline
Old 05-05-2008, 06:31 PM   #48 (permalink)
PrEgO CaNe's Avatar
Brendan
yeah i think you'd be fine for that of course if you get like AA for the temp rating would be better of course. but A will work!
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
auto-x mod question Jay Kincannon Autocross & Sanctioned Drag Racing 5 08-25-2007 10:15 AM
Worst day ever, need some tire advice. CANMAN Wheel And Tire Upgrades 4 07-13-2007 05:11 PM
Tire rub gordo Mechanical Problems & Technical Chat 1 03-13-2007 11:49 PM
Tire pressure check method?? MADDOGSI Mechanical Problems & Technical Chat 19 02-19-2007 02:14 AM
Good deal/Great Service - Discount Tire less Wheel And Tire Upgrades 5 08-19-2006 10:40 PM
Powered by vBulletin® Version 3.7.0
