Click Here
Old 06-15-2007, 11:28 AM   #1 (permalink)
Deez_Nutz1085's Avatar
Need help with Alignment
I just lowered my 07 Civic LX. I've got 17" ADR Battle EXE wheels with 215x45x17 tires and Skunk2 lowering springs at a 2.25" drop. I need to get the tires aligned but need the specs. HEEEEELP!!! : )
Deez_Nutz1085 is offline
Old 06-15-2007, 12:01 PM   #2 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Front camber: 0° 00' (±30')
Rear camber: -1° 30' (+1° 5'/ -0° 45'). Note: Negative is in at the top
You definitely need a camber kit to get within those specifications.
Yodums is offline
Old 06-15-2007, 12:13 PM   #3 (permalink)
Thanks. Why do you say I need a camber kit?
If possible, could you provide the stock settings for
Camber, Toe, and Differential?
Thanks
Old 06-15-2007, 12:29 PM   #4 (permalink)
cojaro's Avatar
You need a camber kit because you've lowered your car a substantial amount and the suspension geometry is definately outa whack. If you don't correct your camber to stock or handling settings, then your tires may wear out in a mere 5,000 miles, if not less.
Any alignment shop should have the factory specs on the computer, but if you want to change any of that, talk to them and they'll change it to your specs.
cojaro is offline
Old 06-15-2007, 12:36 PM   #5 (permalink)
what kind of settings to you guys recommend for the best handling.
Old 06-15-2007, 03:23 PM   #6 (permalink)
cojaro's Avatar
For the street, I'd go with -0.5* to -1.0*camber up front and -1.0* camber in the back. Any more would probably be a bit too aggressive for the street and for a daily driver; plus, it would wear your tires pretty quick. As far as toe goes, I'd ask the suspension guru Highrev1.
cojaro is offline
Old 06-15-2007, 04:40 PM   #7 (permalink)
thanks alot man.
Old 06-15-2007, 07:07 PM   #8 (permalink)
Try "Search"
There is a great thread on this subject if you spend a little time finding it.
Jay Kincannon is offline
Reputable Alignment Place in Baltimore mishima8 Mid-Atlantic 9 05-10-2007 11:33 AM
Alignment in the Dealer? kicker_jace Civic Coupe And Sedan 8 04-26-2007 02:42 PM
Service Manual Alignment Specs? Goose Suspension and Brakes 8 12-08-2006 05:18 PM
good alignment shops in the southbay? junsu California South 1 11-30-2006 07:01 PM
fg2 alignment? subieguy83 Suspension and Brakes 0 04-04-2006 07:34 PM
