Click Here
Old 11-29-2006, 10:08 PM   #1 (permalink)
Tein S-tech + 16" rims = too low??
ok im gonna get Tein S-tech springs and the car is supposed to be lowered a little under 2"...now i want to get some 16" rims...will the combo of both make my car too low? will it scratch if i go over speed bumps??
need feedback pls!
imtim25 is offline   Reply With Quote
Old 11-29-2006, 10:21 PM   #2 (permalink)
negativezeroz's Avatar
16" Won't make it lower because your tire size should increase....
negativezeroz is offline   Reply With Quote
Old 11-29-2006, 10:23 PM   #3 (permalink)
it wouldnt even though i have 17" wheels??
Old 11-29-2006, 10:26 PM   #4 (permalink)
Like if you got 16", generally your tire size will grow to be about same sidewall height as your 215/45's...It might drop it tad more but yeah..
Old 11-29-2006, 10:30 PM   #5 (permalink)
o ok thanks for clearing it up.
Old 11-30-2006, 10:28 PM   #6 (permalink)
Before you go and lower it, what is the tire size you are going with?
Old 11-30-2006, 10:45 PM   #7 (permalink)
im not totally sure about it becuase its a maybe.
Old 11-30-2006, 10:52 PM   #8 (permalink)
Lowering the car thru spring/shock combos doesn't really lower your car that much. Should be ok...
P4rD0nM3 is offline   Reply With Quote
Old 12-01-2006, 12:58 AM   #9 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Run with 205/45 gives you about .4cm difference, it probably won't show much change at all.
Old 12-01-2006, 03:13 AM   #10 (permalink)
Caper's Avatar
Thats right for 205/45r17 but for 16" rims he would have to go with 205/55r16, 205/50r16 or a 215/50r16... the latter being the closest in overall diameter to the stock 215/45r17.
Caper is offline   Reply With Quote
Old 12-01-2006, 10:58 PM   #11 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Why can't he use 205/45?
Old 12-02-2006, 09:12 AM   #12 (permalink)
SIpimpin13's Avatar
16" rims for the loss....
SIpimpin13 is offline   Reply With Quote
Old 12-02-2006, 10:01 AM   #13 (permalink)
Caper's Avatar
He could use it... nothing saying he can't. But using a 205/45R16 would result in 1.3" less in overall diameter compared with stock 215/45R17... Even a 215/45R16 is an inch less. If that is what you are looking for though, by all means it is useable, although it will throw your speed off.
Old 12-02-2006, 11:22 AM   #14 (permalink)
Ryan
I am currently running 16 inch Rota GT-3's with a 205/45/R16 tire. I am dropped on TEIN SS coilovers and I have to say the ride is great. I really don't scrape that much. I drive the streets of Baltimore and the only time I have a problem is if I hit a big dip or pothole the front of the car (presumably the tow hooks) will bottom out and the car will hit. Other then that no problems with speed bumps or driveways. As long as you are careful / take things at a angle you will be fine.
CANMAN
CANMAN is offline   Reply With Quote
Old 12-02-2006, 02:54 PM   #15 (permalink)
a birdie w/o a Katana....
Nomar06's Avatar
wondering why you want to go down in rim size?
Nomar06 is offline   Reply With Quote
Old 12-02-2006, 06:37 PM   #16 (permalink)
MonkayMan17's Avatar
can you post some pics of your drop?
MonkayMan17 is offline   Reply With Quote
Old 12-02-2006, 08:55 PM   #17 (permalink)
Ryan
I will post pics of my drop when I get home from work tonight at 11PM
CANMAN
Old 12-03-2006, 12:35 AM   #18 (permalink)
Ryan
Check my new post in the Intro/pics thread.
CANMAN
TEIN Basic, Super Street, FLEX Coilover and S-Tech/High Tech Spring Sale Excelerate Excelerate Performance 39 07-11-2008 11:12 AM
So if we have a coupe and 18 inch rims how low can we go? Civic Pride Suspension and Brakes 3 12-01-2006 04:01 PM
205/60/R16 on Stock EX Coupe 16" Rims ? Mateen Wheel And Tire Upgrades 4 11-24-2006 10:20 AM
Struts with TEIN S TECH SPRINGS??? 06RALLYREDSI Suspension and Brakes 10 09-19-2006 02:25 PM
