Click Here
Old 11-06-2006, 12:15 AM   #1 (permalink)
GALAXY~SI's Avatar
Kurt
need help from the 8thcivic
hey i was intrested in purchsing these but i dont know what all this crap means like 35mm and hub 73 help me out thanks
http://store.racinglab.com/rota-d2-1...143-35-73.html
GALAXY~SI is offline
Old 11-06-2006, 12:35 AM   #2 (permalink)
Phil
the +35mm is the offset. I'm not exactly sure of the offset needed to clear the brake calipers on the Si...i wanna say around the 40's are pretty common... as for the HUB 73...I really have no clue on
Htuner34 is offline
Old 11-06-2006, 04:06 AM   #3 (permalink)
GALAXY~SI's Avatar
Kurt
soo 35 probally would'nt clear the brakes correct. well thanks anyone know what the hub 73 is?
Old 11-06-2006, 04:30 AM   #4 (permalink)
I hate you
ILL FG2's Avatar
AJ
It should be fine with clearing the brakes, but that has as much to do with the spoke design as the offset. However, if you're lowered you'll probably have to roll the fenders or run a 215 width tire to fit. I've got some 17x8 +33 work meisters (the wheels that these are a knock-off of) on the way, so I'll keep everyone posted on whether or not a spacer is needed in front.
"8thcivic.com where everyone holds hands, nutswings and paints everything in time attack fashion"
-Michael Bolton
ILL FG2 is offline
Old 11-06-2006, 04:48 AM   #5 (permalink)
Xenin's Avatar
Captain Projectors
73 is the hub diameter of the wheel center on the inside. it needs to match up to the diamter of the wheelhub of the car its going onto. if the wheelhub of the car is smaller than the rim you're putting on you'll need hubcentric rings to make sure that there is no empty space between wheelhub and rimhub. if you do not use the hubcentric rings you'll feel shaking from the wheels when driving at higher speeds.
example: wheelhub is 65 and rimhub is 75, then you need a hubcentric that is 65 on one side and 75 on the other side of the ring to mate up properly.
Xenin is offline
Old 11-06-2006, 04:56 AM   #6 (permalink)
GALAXY~SI's Avatar
Kurt
then i guess the new ? is what the hub centric of the SI lol
Old 11-06-2006, 05:02 AM   #7 (permalink)
Xenin's Avatar
Captain Projectors
did a little search here, should be 64.1mm. that sounds about right since my 03 civic coupe had the same bore.
Xenin is offline
Old 11-06-2006, 10:33 AM   #8 (permalink)
GALAXY~SI's Avatar
Kurt
so like you said before what i would need is 64.1 and then the 73 from the rotas and i should be straight
this is a headache for a pari of rimss lol
Old 11-06-2006, 02:43 PM   #9 (permalink)
I hate you
ILL FG2's Avatar
AJ
yes its fine, you'll just need the hubcentric rings.
-Michael Bolton
ILL FG2 is offline
Old 03-12-2007, 02:20 AM   #10 (permalink)
sweger's Avatar
Nik Sweger
anyone know where to get these hubcentric rings?
sweger is offline
Old 03-12-2007, 02:24 AM   #11 (permalink)
FG Squad Member #15
You can get them off ebay for like $12 shipped. I got a set off there for my Volks a couple weeks ago.
06Fg2 is offline
8thCivic Frappr Map - Show us where you are! 8thgenuser Water Cooler 91 09-05-2008 06:49 PM
Video: Beating the crap out of 8thcivic on the dyno and in the street yusk8te Civic Coupe And Sedan 16 08-31-2006 11:27 PM
8thcivic Store Adds New 2006 Honda Civic Parts webby 8thcivic.com Site News 19 06-07-2006 12:29 PM
8thCivic Shirts & Goodies Silver8th CorSport 1 12-01-2005 04:18 AM
