Is it normal when your tires make a loud humming sound while driving - 8th Generation Honda Civic Forum
Old 09-10-2009, 09:01 AM   #1 (permalink)
HLeasy's Avatar
Huey Le (TEAM V2LAB)
i just got some new tires mounted on my 17 wheels about a week now
the tires are 225/45/17, every time i drive, slow or fast, the sound keeps coming
i wanted to know if this was normal, or b/c its brand new tires, and it would slowly go away as it ware out
HLeasy is offline
Old 09-10-2009, 09:34 AM   #2 (permalink)
UniqueTW's Avatar
Mike.
what kind of tires are they ?
UniqueTW is offline   Reply With Quote
Old 09-10-2009, 09:38 AM   #3 (permalink)
ocdcivic's Avatar
Ray
Is your car lowered at all? Only reason I ask is that if you have done a lot of aggressive driving with bad camber settings you could have worn the tires irregulary already.
+1 for brand of tires.
ocdcivic is offline   Reply With Quote
Old 09-10-2009, 10:25 AM   #4 (permalink)
+1 for info
does the soudn go away depending on t he surface you drive on?
does the soudn change as you vary speed?
Chicken Hawk is offline   Reply With Quote
Old 09-10-2009, 10:51 AM   #5 (permalink)
SiLentPower's Avatar
Joe
Yeah, we do need to know what tires. Different tires have different noise ratings. For instance, bf-goodrich t/a kdw's are really noisy on the highway
SiLentPower is offline   Reply With Quote
Old 09-10-2009, 10:55 AM   #6 (permalink)
High Revs Si's Avatar
Ron
If you're running the OEM 17's why did you go wider?
High Revs Si is offline   Reply With Quote
Old 09-10-2009, 11:03 AM   #7 (permalink)
asianskater91's Avatar
david
i think it would be because all the new tread on there...i mean if you hear trucks with like deep tread you can always hear a humming noise inside and outside of the vehicle but thats jus what i think...
asianskater91 is offline   Reply With Quote
Old 09-10-2009, 11:15 AM   #8 (permalink)
Piotrush's Avatar
Peter
Also is your air pressure at the proper level?
Piotrush is offline   Reply With Quote
Old 09-10-2009, 12:18 PM   #9 (permalink)
cypress's Avatar
Kenny
i think the tires have a good factor, i just changed my tires and noticed a huge difference in the road noise. love my new tires now
cypress is offline   Reply With Quote
Old 09-10-2009, 01:09 PM   #10 (permalink)
If you mean the speed you are driving doesn't matter, then it might be the wheel bearing is failing....
Kucaci is offline   Reply With Quote
Old 09-10-2009, 01:15 PM   #11 (permalink)
david
^^^that would suck haha
Old 09-10-2009, 02:03 PM   #12 (permalink)
HLeasy's Avatar
i have stock springs no drop yet
they are brand new wanli tires 225/45/17
i just got them mounted on and the psi are correct at about 37
the sounds skips repeatedly,a sort of loud hum
when i slow down that sound is lil higher than when i speed
HLeasy is offline   Reply With Quote
Old 09-10-2009, 02:09 PM   #13 (permalink)
HLeasy's Avatar
the tires are mounted on advan rg2 17x8 +37
Old 09-10-2009, 02:24 PM   #14 (permalink)
Post Whore
galaxygrey13's Avatar
Antonino B. B. Leyva
wanli tires? wtf?
galaxygrey13 is online now   Reply With Quote
Old 09-10-2009, 05:36 PM   #15 (permalink)
Yup~~if the loud hum can almost surpass the sound of your music~~~then go check your wheel bearing soon. There's a recall on ABS o-ring that's relate to this problem.....
Old 09-10-2009, 06:37 PM   #16 (permalink)
returnoftheSi's Avatar
Jason
Could be those crappy Wanli tires or the wheel bearings. Do you have another set of wheels/tires you could temporarily swap to see if the sound goes away? Or maybe swap on a buddy's set and do a quick test. If the sound doesn't go away it's most likely the bearings.
returnoftheSi is offline   Reply With Quote
Old 09-10-2009, 06:38 PM   #17 (permalink)
iDrive's Avatar
Bryce
you put wanli tires on advan rg11's?
iDrive is offline   Reply With Quote
Old 09-10-2009, 06:40 PM   #18 (permalink)
trickyazn's Avatar
RGII*'s
lol @ cheap tires on semi-expensive rims
Old 09-10-2009, 06:46 PM   #19 (permalink)
Ayodog's Avatar
rori ( f*ck your form ) <3
Originally Posted by trickyazn View Post
RGII*'s
cuz more then half the people with the expensive rims dont ?
Ayodog is offline   Reply With Quote
Old 09-10-2009, 06:46 PM   #20 (permalink)
I needa cop RG11's pronto.
twix562 is offline   Reply With Quote
Strange Humming Sound tjaikens Mechanical Problems & Technical Chat 6 11-19-2008 04:32 PM
driving over snow is extremely loud SilentBob420BMFJ Civic SI 5 03-23-2008 04:00 PM
loud sound.when shifts jayhomies-lx Mechanical Problems & Technical Chat 1 10-27-2006 02:32 AM
Strange humming sound? chylld Mechanical Problems & Technical Chat 21 10-02-2006 02:03 AM
Does this sound normal to you? mcmajo Mechanical Problems & Technical Chat 8 08-24-2006 12:29 AM
