The Official Wheel Fitment Manual - Page 42 - 8th Generation Honda Civic Forum
Old 02-25-2015, 02:41 PM   #821 (permalink)
aceasarsalad's Avatar
kanyedian™
aceasarsalad just put it into 1st gear on 8thcivic
Garage
Originally Posted by Sprinqer View Post
Sooo quick question for the stance veterans, if I get some 15mm spacers (at 35 offset now) will I need camber kits or will just a roll suffice? Pic for reference.
aceasarsalad is offline   Reply With Quote Quick reply to this message
Old 03-01-2015, 06:24 AM   #822 (permalink)
cloud9bill just put it into 1st gear on 8thcivic
ok i have read though half the thread, i need help with tire size on these wheels please, i have rub my front suspension with 245/40 tires, will 215/40 all around be ok??? thanks 17x9 +45 front and 17x9 +38 rear
cloud9bill is offline   Reply With Quote Quick reply to this message
Old 03-01-2015, 01:20 PM   #823 (permalink)
kevin
kevgraydog just put it into 1st gear on 8thcivic
I wonder if u can do a small spacer up front to cure it? Luv the wheels! ! I was thinking of getting those instead of rpf1s. Do u have a pic with thise on your car?
kevgraydog is offline   Reply With Quote Quick reply to this message
Old 03-01-2015, 01:44 PM   #824 (permalink)
JDM-FG2_'s Avatar
JDM-FG2_ just put it into 1st gear on 8thcivic
Garage
I think you could make the 245's work with a spacer.
17x9 with a 215/40 would be a stretch.
JDM-FG2_ is offline   Reply With Quote Quick reply to this message
Old 03-02-2015, 04:05 AM   #825 (permalink)
i just got the car a few weeks ago, traded my s2k due to having a 3 month old needing a 4 door, here is a pic, had these on the s2k now on the fa5
Old 03-02-2015, 03:48 PM   #826 (permalink)
kevin
Nice!! I agree 215 would be a stretch also. 235s would be better. How do u feel the Si compares to your s2000?
Old 03-02-2015, 04:09 PM   #827 (permalink)
Broke Baller
pgFA's Avatar
Pogi
pgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warriorpgFA is the 8thcivic ninja warrior
What are you lowered on? 235/40 will be a good option for you. Depending on what exactly you're trying to do. 215/45 or 225/45 if you want to stretch the tires but 215/40 wont be a comfy ride for your little one.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
pgFA is offline   Reply With Quote Quick reply to this message
Old 03-02-2015, 08:17 PM   #828 (permalink)
I'm thinking 235 may still rub, the s2k handles amazing compared to the si. I'm def gona get another one in the future. Here is a pic of the s2k
Old 03-02-2015, 08:21 PM   #829 (permalink)
I'm lowered on d2's I just don't want a gap without rubbing the suspension, just lowered not slammed, 215/45 or 225/40 I'm thinking with 5mm spacers in front. Thanks everyone
Old 03-03-2015, 07:13 PM   #830 (permalink)
da is best's Avatar
da is best just put it into 1st gear on 8thcivic
that s2k is so sick, damn kids ruin everything
da is best is offline   Reply With Quote Quick reply to this message
Old 08-20-2016, 11:05 AM   #831 (permalink)
Mightymousetech just put it into 1st gear on 8thcivic
Just joined the forum, first post.
Picking up a 2007 Si Coupe as a winter car/summer track/autox toy.
Will be ordering a KW V3 coil over kit, Progress rear 24mm bar and need the biggest rubber I can stuff in the fenders. Have been reading through this thread, and there are so many tangents it is hard to find an answer. This is what I am thinking for wheels/tires.
Enkei RPF1 17x9 ET 45
BFG R1 245/40/17
Front H&R 10mm spacers
Anybody running this setup? Looking for a quick answer so I can order everything in one shot and hopefully make the next autox in a couple weeks.
Edit:or should I get 17x8.5 ET 40?
Mightymousetech is offline   Reply With Quote Quick reply to this message
Old 08-20-2016, 07:29 PM   #832 (permalink)
JDM-FG2_'s Avatar
Garage
BFG R1 245/40/17
That actually sounds like a pretty good setup to me. I'm sure you could make that fit.
Only thing i'm unsure about right now is the rear. I don't think you'll hit the suspension, but you'll need to roll fenders a little bit for sure.
Will you be adding new rear camber arms for rear and bolts up front as well?
Sent from AutoGuide.com Free App
Old 08-20-2016, 07:45 PM   #833 (permalink)
Already have a couple sets of front OE camber bolts, so I can play with that, had them on a previous FG2. Will get adjustable arms for the rear if needed.
Seems like the front springs are pretty long on the V3. Luckily they are a standard size race spring, so can always get springs of the same rate, just a couple inches shorter so the perch sits above the tire and not beside it. This is pretty common to do on the 135's as the front is pretty tight and you need as much rubber up front as possible to reduce understeer.
Also don't mind rolling the fenders a bit.
Hopefully the 17x9 fit with the 245's, will be ordering them from Tirerack already mounted, so no going back.
Had 17x8 +45 with 235/40/17 before, and those bolted on and never rubbed.
Old 10-15-2016, 10:37 PM   #834 (permalink)
Bizzaro00 just put it into 1st gear on 8thcivic
Nice thread definitely answered my questions.
Bizzaro00 is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 09:47 PM   #835 (permalink)
0tosixty just put it into 1st gear on 8thcivic
I have a si coupe on stock suspension looking to do some autocrossing. Planning on getting a set of RPF1 17x8 wheels, but not sure of the offset and tire size. I want the widest tires without rubbing or doing any body/suspension modifications or spacers.
0tosixty is online now   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/138283-official-wheel-fitment-manual.html
Wheel And Tire Upgrades on 8th Generation Honda Civic Forum | BoardReader This thread Refback 06-27-2011 09:02 PM
Wheel Fitment Recipe - wheel offsets that work FigiSi06 Wheel And Tire Upgrades 2105 02-19-2009 04:01 PM
wheel fitment question? ray316 Wheel And Tire Upgrades 1 04-07-2008 03:09 PM
Wheel fitment?? krazeeboy Wheel And Tire Upgrades 5 10-04-2007 05:40 PM
question about wheel fitment blu06 Wheel And Tire Upgrades 3 12-12-2006 10:11 PM
