On the wheel and tire fitment guide on here, it says you can run a 235 with a 17" 45 offset. I know there is atleast one member on here that is running a 245 on a 17". When I asked him if there was any rubbing issues, he said that only in extreme circumstances. So I'm getting ready to put 235's on my car with s-tech's in the next couple of days and I will let you know.
I have fitted 245 45 17 race rubber on the Si with stock suspension. It rubs in only one spot, on the little plastic screw holding the fender liner almost at the top of the fender and no where else. Now this was during hardcornering autocrossing fun. I would not recommend a 245 45 17 setup of street tires for the street as I found that you'de have ti give up a bit of steering feel and steering response. I also found out that the LSD is a bit weak when you throw in wider size tires. I again found that out during autocrossing, where I was spinning the inside wheels ever so slightly cornering under power.
I would not go beyond 225 45 17s. My .02 cents |
#9 (permalink) | |
mAd 3Rd GEaR VaTTAck !!!!
2006 habenaro red pearl si Eibach sportlines/Skunk2 camber kit/Comptech sts/x's diy intake/4300k hid/Oem fog lights/225-45 bfg kdw's on stock si's/Razo WR shift knob/Auger shift boot
#10 (permalink) | |
#12 (permalink) |
I have 225/45R17 on stock Si rims and suspension, no rubbing. I like the look of the larger diameter tire-it is noticeably larger in diameter and width (to me). Some would say it looks a bit "ballooned" on a 7 wide rim, but I like the extra protrusion because it helps prevent curb rash and gives just a bit more sidewall to protect bending rims and take the California pot holes on my commute. Perfect size.
#13 (permalink) | |
#15 (permalink) |
The original --> "J" <--
![]() I almost bought 225's but then I realized I will rub cuz I am on sportlines. Its possible, but... my theory is honda put 215's on for a reason, so personally I like that that way |
#17 (permalink) |
i have 225/45/17 Bridgestone Potenza RE-01R's on the stock Si wheels and I am also lowered on Sportlines. I've only rubbed like twice and it was taking a corner really fast. You can corner spiritedly without any problems but if it is thrown into a corner near it's limits, it will rub. I plan on increasing the negative camber this summer and we will see if that helps. Oh and it only rubs up front :) no problems in the rear.
#18 (permalink) | |
| Value of EX rims and stock tires with 18k miles? | less | Wheel And Tire Upgrades | 4 | 08-10-2006 02:17 PM |
| Rims on Stock tires | hoanger | Wheel And Tire Upgrades | 5 | 06-07-2006 08:30 AM |
| New wheels on stock tires. | ballplaya4237 | Wheel And Tire Upgrades | 8 | 05-23-2006 03:25 PM |
