Click Here
Old 11-30-2008, 11:02 AM   #1 (permalink)
Kitties rule, dogs drool.
xheartcore_boyx's Avatar
Addy
Do i need centering rings?
So, i have ordered some Advan rz 18", they are getting installed along with many other goodies on January, so i want to order everything i need now, since shipping overseas takes forever.
The wheels do not come with centering rings, do i need these? is it better to get them? do centering rings differ depending on the wheels?
-if it helps to know, drop: hfp camber: spc rear arms and front bolts.
Thanks for any helpful responses.
xheartcore_boyx is offline   Reply With Quote
Old 11-30-2008, 11:05 AM   #2 (permalink)
Addy
My 17" 500$ previous wheels used to vibrate when braking from high speed, dont know if its going to be any different with quality wheels.
Old 11-30-2008, 11:12 AM   #3 (permalink)
Tod
Short answer... Yes!
Solo2EG is offline   Reply With Quote
Old 11-30-2008, 11:14 AM   #4 (permalink)
Addy
Long question, which ones shall i get? does the wheels model matter?
Old 11-30-2008, 11:26 AM   #5 (permalink)
e60.deluxe's Avatar
you should be able to order some from the place you get the wheels from. just tell them you have a hub diameter of 64.1mm. most wheels will use 73.1 so i assume but you should check with whos selling you wheels. if you they dont sell you them, atleast find out, then you can get something like this:
Hub ring aluminum 73.1/64.1 [AN731-641] - $0.00 : Bimecc USA, Catalog
e60.deluxe is offline   Reply With Quote
Old 11-30-2008, 11:26 AM   #6 (permalink)
ray
ray's Avatar
Wheels differ, and one of the ways the differ is the bore size. That being the diameter of the hole in the center that fits over the car's hub. The hub on 8G civics is 64mm, so the hole in the wheel needs to match that in order to properly center the rim. The fit between the bore of the wheel and the hub is what establishes the alignment between the two, rather than the lugs.
OEM wheels are engineered to fit the car they come on. As such, the bore in the wheel will match the hub with no centering ring. Aftermarket rims are generally designed to fit as wide of selection of cars as possible, and as such have a larger than necessary bore and rely on a centering ring to adapt it down to the hub or your choice.
Given the kind of money that Advans cost, you think they could afford to have seperate versions with the bore size of your choice. If this is not the case, you will need a centering ring that adapts whatever the bore size is on the Advans you are getting to the 64mm hub of the civic. This centering rings are generally .1mm larger than the hub to allow enough clearence to fit over the hub. .1mm is less than .040", allowing them to fit over the hub.
ray is offline   Reply With Quote
Old 11-30-2008, 11:56 AM   #7 (permalink)
Addy
So, how do i know what bore size does the RZ's have?
i got this from my quote:
POSelID: p1011: o814:RZ Wheels 5x114.3 18x8.0 ET+37 - Dark Gun Metal - GT-R Model
Wheel Selection:RZ Wheels 5x114.3 18x8.0 ET+37 - Dark Gun Metal - GT-R Model=+339.43W+13
Does this code include the bore size?
Old 11-30-2008, 12:31 PM   #8 (permalink)
ray
ray's Avatar
Maybe ask someone who sells them?
Old 11-30-2008, 03:10 PM   #9 (permalink)
VanSin23's Avatar
Van (08 ASMFA5)
once you receive them, measure the bore on the wheels with a caliper to determine the size you need.
VanSin23 is offline   Reply With Quote
Old 11-30-2008, 03:25 PM   #10 (permalink)
Addy
measure the bore with a caliper?! how?
Old 11-30-2008, 05:34 PM   #11 (permalink)
e60.deluxe's Avatar
do you know how to use a caliper? its not very difficult. also, simply calling any place that sells the wheels should suffice as well.
edit: i just realized that maybe you dont know what a caliper is in terms of a tool and not brake component:
Old 12-01-2008, 01:38 AM   #12 (permalink)
Addy
Oh yes i though it was the braking caliper first, the shop that i go to have you, they can measure it for me later, but i will call the company i got my wheels from to check anyway..
btw, off-topic but how do i know if this shop REALLY can install my hfp suspension? its a performance shop, they will use jack stands..they work on evos and z06s all day but i dont know..what can i ask them to see if they got an idea?!
Old 12-01-2008, 02:44 AM   #13 (permalink)
Xenin's Avatar
K.C. -- Captain Projectors
it'll say on the box what the hub bore is. you could always e-mail Advan and ask as well.
Xenin is offline   Reply With Quote
Old 12-01-2008, 03:53 AM   #14 (permalink)
Addy
If it is on the box then its all fine, will order them centering rings when i get the wheels, i will have like a whole month until starting installing my parts, thanks everyone for the inputs!
Old 12-02-2008, 01:02 AM   #15 (permalink)
Addy
Bump!
Just got this from the company "The size of hole in the centre of Advan wheels is 73mm"
so the bore size on the wheels is 73mm, my hub is 64.1mm, true?
So what centering rings size shall i get? where to get from? heard that plastic is better than metal since it doesnt rust, true?
thanks.
Old 12-02-2008, 01:17 AM   #16 (permalink)
ff_29's Avatar
1. you need 73(outer)-64.1(inner) ring.
2. you can get it from any wheel shop, or ebay
3. not sure that they make steel hubcentric rings. I'm pretty sure mine are aluminum (no rust).
i'd order them now so you don't have to wait for them after you get your wheels.
Excellent choice with the RZs, I thought you'd be going volk by the sounds of your thread.
ff_29 is offline   Reply With Quote
Old 12-02-2008, 01:30 AM   #17 (permalink)
Addy
I will look for these online now, and yes i was going with volks first, but i always knew that i liked the advan rz better and was just confusing myself, so happy with my purchase though! (they left today )
thanks for the help!
Old 12-02-2008, 01:34 AM   #18 (permalink)
Xenin's Avatar
See what I told you, when in doubt just email.
Old 12-02-2008, 01:36 AM   #19 (permalink)
Addy
yep they responded pretty quickly!
Old 12-02-2008, 01:38 AM   #20 (permalink)
Xenin's Avatar
Good stuff.
Anyone!! whats a centering ring? todd_tampabay Wheel And Tire Upgrades 6 09-27-2008 10:15 PM
centering rings stixs Tire, Wheel, Brake & Suspension Forum Sponsored By The Tire Rack 8 03-06-2008 05:20 PM
centering rings stixs Tire, Wheel, Brake & Suspension Forum Sponsored By The Tire Rack 0 03-05-2008 06:24 PM
centering rings stixs Tire, Wheel, Brake & Suspension Forum Sponsored By The Tire Rack 0 03-05-2008 06:17 PM
Alignment and Wheel Centering bluesunit Suspension and Brakes 18 01-20-2008 11:58 PM
