#101 (permalink) | |
Chris
oh... and THANK YOU for searching instead of just making a new thread for your question. Most people dont do that. Its refreshing to know some people can still attempt to find answers on their own |
#106 (permalink) |
David
Anyone know of a good receiver that I would be able to read pressure/temp since I understand that the sensors broadcast this info even though the stock TPMS receiver doesn't have a way to display it. I'm doing a long term study on the effects of pressure on MPG and one of the variables I have to track is the temperature.
#109 (permalink) |
I bought a new '08 Honda Civic several months ago. A few weeks ago I had a blowout and after the new tire was put on the low pressure light stayed on. Shortly thereafter I returned to the dealership where I bought the car and asked them what it would take to disable the light, figuring it wouldn't cost anything. Instead I was told that it would cost $170 to replace a sensor. I was also told that perhaps the guy who changed my tire had inadvertently damaged the sensor. Or that it could've been damaged when the blowout occurred. Anyhow, my dealer wanted to charge me $170 to replace it! My brother who's in the tire business advised me to just forget about it and drive with the light on, which is what I've done. Then last week I noticed that the low pressure light had gone out but that a new light, TPMS, had come on and is still on. I'm figuring that if no damage was done driving with the low pressure light on, then it's probably okay to drive with the TPMS light on. At any rate, I can't see paying $170 per sensor anytime I have a similar problem. I figure if there's really a problem, my warranty should cover it.
When I first informed my salesperson about the low pressure light staying on, he told me that my car was under warranty and I would not be charged to turn it off. Obviously, the service department told me differently. In the meantime, I continue to drive with the TPMS light on, hoping that all is okay. |
#112 (permalink) | |
Chris
however, I think the $170 likely included the new sensor, mounting and rebalancing the tire and reprogramming the sensors... im not sure. Either way, it shouldve been covered under warranty i asusme correct |
#113 (permalink) |
CBR307000 Save $$ on Textbooks
^^^thank god!! im swaping my stock wheels for a set of Si's and EVERY Honda service rep iv called didnt know. i was just worried that after i did the swap, a tire pressure light would come on my dash instantly killing the joy of having a different set of wheels on my car
#114 (permalink) | |
#115 (permalink) |
Kickin' ass, takin' names...
ok, since this hasn't been brought up yet, is there any way at all to disable the TPMS completely? What i mean is since I have wheels that dont have tmps' and my light is always on, can we trick the car to think that it does have them OR can we disable the system altogether?
And from what Hondata just told us on the Flashpro thread, page 37: "TPMS is not controlled from the ECU." How and where is it controlled? Wish there was just a fuse to pull like the DTRL... |
#116 (permalink) |
Chris
Currently Im unaware of a way to 'trick' the system. The common 'sensors in a pressurized pvc pipe' doesnt work.
If its not controlled by the ECU, then im not sure what else it would be controlled by. |
#117 (permalink) |
The tire pressure monitoring system (TPMS) is controlled by the TPMS control unit. There's no way to disable the TPMS system without illuminating the TPMS light and setting a variety of communication DTC's. The TPMS control unit communicates with the ECM/ PCM and gauge control module (tach) via the F-CAN communication network.
#118 (permalink) |
Chris
Good info ^
Im not sure why the light bothers os many people. If you 'dont need the idiot light', then just ignore it. IMO its not any more annoying than the lights that tell you your headlights/foglights are on. |
#119 (permalink) | |
But phalanx, the light is not the issue, i'm not bothered by the light at all...i want to deactivate the VSA and we can't if that TPMS light is on... Last edited by the 8k rev; 05-11-2009 at 06:48 PM. |
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/123148-faq-tire-pressure-monitoring-system-tpms.html
| Running Winter Wheels Without TPMS Sensors - Disable VSA? - 9th Gen Civic Forum : 2012 Honda Civic Forums - 9th Generation | This thread | Refback | 09-17-2011 12:33 PM | |
| Running Winter Wheels Without TPMS Sensors - Disable VSA? - 9th Gen Civic Forum : 2012 Honda Civic Forums - 9th Generation | This thread | Refback | 09-17-2011 09:53 AM | |
| Where to get TPMS reset tool? | This thread | Refback | 09-11-2011 11:14 PM | |
| tire pressure sensor, reset? - Honda-Tech | This thread | Refback | 08-30-2011 09:01 AM | |
| tire pressure sensor, reset? - Honda-Tech | This thread | Refback | 08-26-2011 10:33 PM | |
| TPMS systems - Car Talk | This thread | Refback | 06-19-2011 12:08 PM | |
| Mugen i-TCMS (Intelligent -Tire Condition Monitoring System) | B-b0y | Wheel And Tire Upgrades | 10 | 09-18-2008 10:39 AM |
| Winter wheels/tires,not using Tire pres. monitoring... | Crusin_w00kie | Wheel And Tire Upgrades | 2 | 08-16-2008 01:23 AM |
| 07 Si Coupe and Tire Pressure Monitoring? | NiD4SPD | Wheel And Tire Upgrades | 7 | 11-12-2006 12:51 AM |
