#1 (permalink)
DIY: How to speed up firefox.
Just found this and it is a night and day difference:
Useful guide on speeding up firefox for broadband users 1.Type about:config into the address bar and hit return. Scroll down and look for the following entries: network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading. 2. Alter the entries as follows: Set "network.http.pipelining" to "true" Set "network.http.proxy.pipelining" to "true" Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once. (the trick here is clicking the false word and it will change to true) 3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives. If you're using a broadband connection you'll load pages MUCH faster now! |
#10 (permalink) |
![]() Join Date: Apr 2006
Dent
your exact post in the comments section here, word for word....
Geek to Live: Top Firefox 2 config tweaks Here's a more comprehensive guide: Tweakfactor.com: Firefox Tweak Guide - Page 1 - Get your tweak on! And some common configurations for different computers with different connections. The Firefox Tweak Guide has the full details on how to speed up Firefox regardless of your connection or hardware, reprinted in part below. Don’t forget that the easiest way to tweak user files is with chromEdit extension. Common to all configurations These are the settings that seem to be common to all configuration files regardless of connection speed or computer speed with a couple of additions - plugin paths can be found with about lugins and the bookmark menu delay is turned off.user_pref("network.http.pipelining", true); user_pref("network.http.proxy.pipelining", true); user_pref("network.http.pipelining.maxrequests", 8); user_pref("content.notify.backoffcount", 5); user_pref("plugin.expose_full_path", true); user_pref("ui.submenuDelay", 0); Fast Computer Fast Connection user_pref("content.interrupt.parsing", true); user_pref("content.max.tokenizing.time", 2250000); user_pref("content.notify.interval", 750000); user_pref("content.notify.ontimer", true); user_pref("content.switch.threshold", 750000); user_pref("nglayout.initialpaint.delay", 0); user_pref("network.http.max-connections", 48); user_pref("network.http.max-connections-per-server", 16); user_pref("network.http.max-persistent-connections-per-proxy", 16); user_pref("network.http.max-persistent-connections-per-server", 8); user_pref("browser.cache.memory.capacity", 65536); A couple settings of note - Firefox is allocated 4096 KB of memory by default and in this configuration we give it roughly 65MB as denoted by the last line. This can be changed according to what is used. Fast Computer, Slower Connection This configuration is more suited to people without ultra fast connections. We are not talking about dial up connections but slower DSL / Cable connections. user_pref("content.max.tokenizing.time", 2250000); user_pref("content.notify.interval", 750000); user_pref("content.notify.ontimer", true); user_pref("content.switch.threshold", 750000); user_pref("network.http.max-connections", 48); user_pref("network.http.max-connections-per-server", 16); user_pref("network.http.max-persistent-connections-per-proxy", 16); user_pref("network.http.max-persistent-connections-per-server", 8); user_pref("nglayout.initialpaint.delay", 0); user_pref("browser.cache.memory.capacity", 65536); Fast Computer, Slow Connection user_pref("browser.xul.error_pages.enabled", true); user_pref("content.interrupt.parsing", true); user_pref("content.max.tokenizing.time", 3000000); user_pref("content.maxtextrun", 8191); user_pref("content.notify.interval", 750000); user_pref("content.notify.ontimer", true); user_pref("content.switch.threshold", 750000); user_pref("network.http.max-connections", 32); user_pref("network.http.max-connections-per-server", 8); user_pref("network.http.max-persistent-connections-per-proxy", 8); user_pref("network.http.max-persistent-connections-per-server", 4); user_pref("nglayout.initialpaint.delay", 0); user_pref("browser.cache.memory.capacity", 65536); Slow Computer, Fast Connection user_pref("content.max.tokenizing.time", 3000000); user_pref("content.notify.backoffcount", 5); user_pref("content.notify.interval", 1000000); user_pref("content.notify.ontimer", true); user_pref("content.switch.threshold", 1000000); user_pref("content.maxtextrun", 4095); user_pref("nglayout.initialpaint.delay", 1000); user_pref("network.http.max-connections", 48); user_pref("network.http.max-connections-per-server", 16); user_pref("network.http.max-persistent-connections-per-proxy", 16); user_pref("network.http.max-persistent-connections-per-server", 8); user_pref("dom.disable_window_status_change", true); One of the changes made for this particular configuration is the final line where the status bar is disabled for changing web pages to save processor time. Slow Computer, Slow Connection We have entered the doldrums of the dial-up user user_pref("content.max.tokenizing.time", 2250000); user_pref("content.notify.interval", 750000); user_pref("content.notify.ontimer", true); user_pref("content.switch.threshold", 750000); user_pref("nglayout.initialpaint.delay", 750); user_pref("network.http.max-connections", 32); user_pref("network.http.max-connections-per-server", 8); user_pref("network.http.max-persistent-connections-per-proxy", 8); user_pref("network.http.max-persistent-connections-per-server", 4); user_pref("dom.disable_window_status_change", true); Last edited by dentrecords; 12-06-2007 at 06:57 PM. |
#18 (permalink) | ||
welcome. |
LinkBack to this Thread: http://www.8thcivic.com/forums/water-cooler/68134-diy-how-speed-up-firefox.html
| Yet another Firefox update - Bad Astronomy and Universe Today Forum | This thread | Refback | 12-08-2007 08:24 AM | |
| Si a little "twitchy" at high speed?? | JerrfyLube | Civic SI | 96 | 12-21-2007 02:46 AM |
| World's fastest car in top speed | NitrousG35 | Garage | 21 | 11-05-2007 06:37 PM |
| Speeding Tickets | RealDeal | Dealership Experience | 64 | 01-04-2007 01:11 PM |
| Honda Racing F1 team sets new Bonneville speed records | marc-o-lishuz | Garage | 0 | 08-11-2006 12:28 AM |
