Old 04-11-2007, 03:23 PM   #1 (permalink)
honda06si's Avatar
justin
math help
can someone explain how to do this???
it says factor the trinomial completly
7x^2 + 16x + 4
^2 means x is to the 2nd power
honda06si is offline
Old 04-11-2007, 03:27 PM   #2 (permalink)
here u go man
7x^2+16x+4
(7x+2)(x+2)
x= -2/7
x = -2
SiLover is offline
Old 04-11-2007, 03:28 PM   #3 (permalink)
honda06si's Avatar
justin
Originally Posted by SiLover
here u go man
7x^2+16x+4
(7x+2)(x+2)
x= -2/7
x = -2
so you got that how??? you take the factors of 4.....1,4 and 2,2 and then factors of 7....1,7 and then just sub them in the parenthesis?
Old 04-11-2007, 03:29 PM   #4 (permalink)
Way2Short's Avatar
do FOIL
First, outer, Inner, and Last
Way2Short is offline
Old 04-11-2007, 03:30 PM   #5 (permalink)
honda06si's Avatar
justin
Originally Posted by Way2Short
do FOIL
i know how to do that but its doing it backwards...it confuses me
Old 04-11-2007, 03:33 PM   #6 (permalink)
Way2Short's Avatar
what you mean?
7x X x=7x^2
7x X 2=14x
2 X x = 2X
2X2=4
=====7x^2+16x+4
Old 04-11-2007, 03:35 PM   #7 (permalink)
honda06si's Avatar
justin
sooo
8x^2+6x+1
answer is (4x+1)(2x+1) ?
Old 04-11-2007, 03:37 PM   #8 (permalink)
jonebone's Avatar
Jonas
Yes, I got excited when I saw math in the title, as I thought this would be moderately hard. I'm not saying your dumb (a lot of people have problems with factoring when they first learn it), but I expected at least some integration or some type of calculus
Ahh, having a Bachelors degree in Math and not being able to use it, sigh.
jonebone is offline
Old 04-11-2007, 03:38 PM   #9 (permalink)
NewDanger's Avatar
Originally Posted by honda06si
sooo
8x^2+6x+1
correct
NewDanger is offline
Old 04-11-2007, 03:38 PM   #10 (permalink)
honda06si's Avatar
justin
sorry!!!!
yes im a freshman in college and am in math 012......im actually good at math, but that year and a half off of school, i lost my memory
Old 04-11-2007, 03:39 PM   #11 (permalink)
honda06si's Avatar
justin
You have given out too much Reputation in the last 24 hours, try again later.
i will get u guys when i can give rep again
Old 04-11-2007, 03:39 PM   #12 (permalink)
JUst break it down in your head. What times what equals 7.....umm 7 and 1 and what makes x^2 only x times x.
So we already have (7x )(x )...
Then what times what equals four i chose 2 times 2 because it was the first thing that came to my head.
So now we have (7x 2)(x 2)
In the original equation you had 7x^2+16x+4 so the +4 tells us that either the signs are both going to be + or both are going to be -,and since we have +16x that means we have + signs in both parenthases.
So now we have (7x+2)(x+2) NOw just solve for x..
I Hope this makes sence, becuase it does in my head LOL
SiLover is offline
Old 04-11-2007, 03:40 PM   #13 (permalink)
LOL!!!! yeah i saw math in the title and said forget work let me do some math LOL!!!!
SiLover is offline
Old 04-11-2007, 03:45 PM   #14 (permalink)
spocheld's Avatar
Jeff
sorry!!!!
you're doing that in college I did that in 8th grade, LOL!
spocheld is offline
Old 04-11-2007, 03:45 PM   #15 (permalink)
jonebone's Avatar
Jonas
Lol, you and me both. Just cuz I'm bored:
The derivative of 7x^2 + 16x + 4 is 14x + 16
and the integral is 7/3 x^3 + 8x^2 + 4x + C (C is the constant of integration)
Maybe its over some people's heads, but thats elementary calculus if anyone cares :)
jonebone is offline
Old 04-11-2007, 03:50 PM   #16 (permalink)
honda06si's Avatar
justin
whats your address ill send you a frekin cookie
Old 04-11-2007, 03:51 PM   #17 (permalink)
honda06si's Avatar
justin
so is this one prime?
20x^2-20x-15=
edit--- i got 5(4x^2-6)(2-3)
Old 04-11-2007, 03:55 PM   #18 (permalink)
20x^2-20x-15
(10x-15)(2x+1)
x=15/10 or 3/2
x = -1/2
DOOD are we going to do all of your HW for ya!!!!
SiLover is offline
Old 04-11-2007, 04:07 PM   #19 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
You should get the concept down first, rather than doing it by trial and error.
The first step would be to make sure the equation is correctly arranged, beginning with the highest degree and ending in a constant (if necessary).
You'll notice the first term is the highest degree and it's in a descending order where c is just some constant with no variable attached to it. For this particular example, there is no coefficient (number) in front of the first term, so your factor would look something like this (k is some constant/number):
Both brackets will begin with the variable, x.
Next, the k's or constant will:
1) Have a product (multiply) equal to c (refer to the first diagram - last/third term).
2) Have a sum (added together) equal to whatever bx is (second term of the first diagram).
To make it a little easier, let's use an example with numbers:
What two numbers:
1) Multiply together to give you positive 6
2) Add together to give you negative 5?
Answer is -3 and -2. Since there is no coefficient in front of the first term, you can just stick it in the brackets and go away with it:
If there's a constant in front of the first term which has the highest degree, then you will have to go through a method of trial and error.
For example:
There's a 3 in front of the term with the highest degree, so we can't apply what I initially wrote.
Instead your brackets would look like:
a * c = 3x^2 -----> The first term in the original equation
b * d = 2 ---------> The third term in the original equation
When figuring out numbers, the "bx" term no longer matters.
So what choices do we have for a and c? 3 is a prime number, so it has to be 3 * 1.
The next step would be finding the second terms of both brackets that would give you 2. Let's try -2 and -1.
Well, it didn't work... the method is called trial and error, so let's try switching positions of the -2 and -1 from each bracket:
I hope that helps. Again, get the concept down and then do problems. It would be a mere waste of time to just swap numbers in and out till they work.
Yodums is offline
Old 04-11-2007, 04:18 PM   #20 (permalink)
DAMN Yodums you broke it down......or was that a copy and paste job?
SiLover is offline
What grade of gas? All gas questions answered! **Merged all gas threads** clm10k Civic SI 871 09-05-2008 06:02 PM
time for a math lesson bboylocob Water Cooler 38 01-13-2007 12:16 PM
Who wants to do Calculus? maiku Water Cooler 70 11-21-2006 07:10 PM
100% Fuzzy Math LunchBoxed Water Cooler 3 10-12-2006 11:57 AM
any math geniuses? Downpour Garage 12 07-26-2006 11:41 AM
