#22 (permalink) |
YOOO-FOOOOoo!!11!
Marc's Garlic Pork Chops
Ingredients: Fast-fry pork chops (about 1cm thin max) Garlic 100% pure virgin olive oil Kikkoman Soy Sauce Rock salt Fresh-ground peppers (not the powdered pepper) 2 whole limes Marinade: Dice up the garlic (1 per pork chop is a good rule of thumb). Coat each pork chop with olive oil and soy sauce (make sure they’re thoroughly coated so the garlic, salt, and peppers stick on the surface) Sprinkle rock salt and peppers (around 1 tablespoon or each for 5 chops) Mix in the garlic and the lime juice Wrap with saran-wrap overnight in the fridge. Cooking: After about 8 hours in the marinade, you’re ready to cook the chops. Use a non-stick Teflon pan with very little olive oil. Cook the chops two at a time, browning one side before flipping them over. Each side should take around 3 minutes to brown on medium-high heat (8/10). Don’t flip the chop back and forth; just lift up a corner to see if it’s cooked. Flip it over only once. Once all the chops are cooked, pour the remaining marinade sauce into the pan, add 25% water, and bring to a simmer for 3 minutes. You can use this sauce to add flavor to your pork chops. Little tip: If you’re feeling adventurous, add 1 tablespoon of balsamic vinegar to your sauce before boiling it. This adds a bit of tanginess. Let the chops sit for about 5 minutes in a plate before serving them. |
#23 (permalink) | |
BBQ Bonanza
Top Sirloin Steak (1 per person) Baking Potato (1 per person) (the following assumes you're cooking for 2-3 people) 1 Red Pepper 1 Green Pepper 1-2 Carrots Head of Broccoli 3-4 Cloves of Fresh Garlic 1/2 Large Red Onion Bok Choy Grill Basket ![]() First things first, a day before you're going to eat, get your steak and marinade it. I personally really like PC Memories of Kobe sauce or Club House Mesquite Marinade or Teriyaki Grilling Sauce, with fresh diced garlic. I like to tenderize the steak a little, with a fork on both sides. I rub the marinade in by hand working it into the holes you just poked in the steak. Let it sit for a day in the fridge and the flavour goes through the whole piece of meat. Insert your own sauce here. For the non red meat eaters, you can substitute chicken. Don't buy frozen stuff, get it fresh from the butcher. Let's begin with the garlic. Remove the skin from the garlic and chop the bottom portion off. Dice your garlic into small cubes about 1/3 the size of a pencil eraser. Clean your baking potato and cut it in half. Insert dollop of margarine, teaspoon of diced garlic. Spread it out over the length of the potato. The majority of your garlic should still remain after loading the potatos. If necessary, dice some more (I use lots). Wrap in foil and place it directly on the BBQ grill over low/medium heat. Flip the potatos every 5-10 minutes. At this point, you can begin your prep work for the veggies. Wash all your veggies. I start by peeling the carrots and chopping them up into thin slices. Place these in your grilling basket. I like to cut them on an angle for presentation. Next, dice the onions into pieces a bit bigger than the size of a quarter. If you prefer, cut even larger pieces. Layer this on top of the carrots. Cut your peppers up into triangles, again just a bit larger than quarters. Place in grilling basket. Cut your bok choy up. Place in basket. Cut the stem of the broccoli off and pull the head apart by hand, into small bite sized pieces. Place on top. Place dollops of margarine on top of the whole basket, and sprinkle the garlic over top. After this point, your potatoes should be well on their way to being fully cooked, so check them out for softness. I use a fork to probe them. Once they are pretty much done, add your veggie basket to the grill and your steaks off to the side. Stir the veggies after about 5 minutes, and flip your steaks. Cook to your preferred doneness, and enjoy.
![]() search · FAQ · rules · report bad post · learn how to spell Quote:
#25 (permalink) | |
bump for more recipes :)
#26 (permalink) |
Wife has a degree in Home Ec. Im not kidding. She use to be a teacher. I haven't cooked a thing in years. Loaded a washer or dryer. Please! I might put a plate or glass in the dish washer. She's very old school. She believes there is mens work and womens work in the home.
Aint my life great.... :) |
#32 (permalink) |
______
heres a simple favorite of mine
Sausages and Peppers 2 12oz packages of Italian sausages, one hot and one sweet 1/2 a cup of beer, give or take Bud Light works well for this 2 Bell peppers, any combination of Green, Yellow and Red works fine 1 large Vidalia or other sweet onion 1 TBS fresh Oregano or 1 TSP dried 1 pound of pasta, usually pene Fry the sausages in the pan until browned on all sides while the sausages are cooking slice the onion in half and then into thin slices and cut the peppers into long slices. Once the sausages have cooked remove them from the pan and deglaze the pan with the beer, using your spatula to get any burnt on pieces of sausage off the bottom. Add the peppers and onions and sprinkle with oregano. Cook for about 20-25 minutes until the onions and peppers are soft, stirring occasionally. While they cook, cut up the sausages. Onions should be sorta golden in color. Add the sausages back in and cook for an additional 10-15 min to heat them back up, serve over the pasta. Last edited by ethlar; 03-28-2007 at 11:27 AM. |
#33 (permalink) |
Slave to the corporation
Time to give this thread a kick in the ass...
Here is the recipe for the bean salad to accompany the salmon, belated but as promised: 1 lb green beans, trimmed 1/2 lb yellow beans, trimmed 1 tbsp. olive oil 2 shallots, diced 1 red pepper, diced 1 clove garlic, minced Glaze: 1/2 tsp. grated lemon rind 2 tbsp. lemon juice 1 tbsp. chopped fresh oregano 1 small clove garlic, minced 1 tsp. Dijon mustard salt & pepper 1/4 c. olive oil 1/2 c. crumbled feta cheese 1/4 c. black olives Cook beans in boiling water until tender, drain well and place in bowl. Heat oil in skillet on med. heat and sauté shallots, peppers and garlic until softened. Add to beans. Whisk together the lemon rind, juice, oregano, garlic and mustard, season with salt and pepper. Drizzle in olive oil and whisk until combined. Pour over beans and toss to coat well. Sprinkle with feta cheese. This recipe compliments the salmon (post #1) very well and can be served hot or cold. |
#35 (permalink) |
kwek kwek
1. Boil a dozen quail eggs until hard. Peel and set aside. 2. Combine 1/4 cup cornstarch, 1/4 cup flour, 1 tsp. salt, 1 tsp. pepper, 1/4 tsp. baking powder and mix in 1 cup ice water. Pass through a sieve to remove lumps. Add yellow food coloring. 3. Heat oil in pan. Dip quail eggs in batter then fry until golden brown. Put on sticks and serve with thousand island dressing or vinegar. |
#36 (permalink) |
maybe i can revive the thread?? well i cant give out any of my recipes (cause they are top secret) but i work in a rest. and i like to experiment with some of my own creations. i will tell you one of my little secrets though...when prepping a hamburger, put just a tad of maple syrup in the raw hamburger and mix it in. it gives a sweet taste. it is vital that you dont put too much, then it just tastes gross. i also put a dab of italian dressing in my scrabled eggs before i cook em. and again, if you put too much, it just tastes gross.
#37 (permalink) | |
Sounds good! I also like to put a bit of maple syrup in when cooking bacon. And thanks for reviving this thread!
![]() Later, I'll post a recipe I made for my dad for Father's Day. Another BBQ'd salmon recipe (I love salmon...) and for dessert I made a marbled angel food cake with chocolate whipped cream, his favourite!
![]() Quote:
#39 (permalink) | ||
Craaazy rabid squirrel
Disciple of Discord
Yeah, ok.Here's a favorite of mine: Quote:
