Old 02-28-2007, 02:51 AM   #1 (permalink)
MordeKyle's Avatar
CFM...PSI question
anyone have anyidea how many PSI is 250CFM???
MordeKyle is offline   Reply With Quote
Old 02-28-2007, 03:00 AM   #2 (permalink)
Tim
Super Moderator
Tim's Avatar
CFM is a unit of air flow not of air pressure as far as I know.
Tim is offline   Reply With Quote
Old 02-28-2007, 11:25 AM   #3 (permalink)
MordeKyle's Avatar
k, ive never used CFM befor, dont really know what it is...
Old 02-28-2007, 01:55 PM   #4 (permalink)
Kidekat's Avatar
+1 on what TIM indicated.
Kidekat is offline   Reply With Quote
Old 02-28-2007, 02:46 PM   #5 (permalink)
XSRCivic's Avatar
yes you are correct. CFM is used to measure flow through an object. If you are speaking of turbocharging, the larger the turbo the more it can flow at a given psi. Example. A T3 Super60 turbo may flow 34 CFM @ 8 psi vs a T28 turbo that flows 25 CFM @ 8 psi. (These numbers arent acurate, just an example)
People usually use psi as a broad unit of measurement when really its all about the flow rate of the turbo itself. The bigger the snail the more she blows.
XSRCivic is offline   Reply With Quote
225-45-R17, answer needed !! tonybui Civic Coupe And Sedan 26 02-20-2007 08:29 AM
How much psi should I have in my tires? BoneStock Do It Yourself Articles 14 08-21-2006 08:55 PM
Quick Question... Ortiz83 Civic SI 5 06-15-2006 12:12 AM
question about integra in japan 2000civic Garage 10 06-10-2006 09:34 PM
