Old 11-27-2005, 09:59 PM   #1 (permalink)
Acorns!
webby's Avatar
how to steal an IS300
taken from my.is
I believe in the freedom of information. For this reason, it is critical that Lexus’ design flaws be exposed. We can only hope to foster improvements and further automotive excellence by sharing information, freely and openly.
Disclaimer: I assume no responsibility for any illegal actions or property damage that may occur as a direct or indirect result of the information contained in this tutorial. Try at your own risk.
Flashlight, wrench, screw driver, 10mm socket, wire cutter, common sense
8/10
7 minutes
Step 1:
Remove door handle. It should come right off.
Step 2:
Sit back and admire your work.
Step 3:
Identify lock release and door lever mechanisms. See picture for details. The lock release is indicated by the red circle. The door lever is indicated by the green oval.
Step 4:
Push down on the lock release lever to unlock the driver’s door. Push down on the door lever to open the door.
Step 5:
Look inside the vehicle, before opening the door. Prepare, mentally, for the task at hand.
Step 6:
Place your high-quality tools on the passenger’s seat.
A close-up of the tools needed:
Step 7:
Start disassembling the dash area.
Step 8:
Examine the ignition barrel.
Step 9:
Expose the wires in the ignition barrel that are covered by the plastic sheath.
Step 10:
Join constant power (white-red) to ignition (black-red).
Touch starter wire (black-white) to exposed metal of joined power and ignition wires. Remove quickly.
Step 11:
Realize that you have no idea what you’re doing.
Run. Leave tools behind.
For the challenged... this post is an attempt at humor. Since being pissed off won't make it any better, I thought that I might as well make this...
This is why key codes are a good thing. The guy didn't get away with his car because lexus uses a computer chip in their keys (like honda). The car would basically crank, but never start without the key present.
wow.
webby is online now
Old 11-29-2005, 11:13 PM   #2 (permalink)
02boostlessVIC's Avatar
damn i would be pissed if it happened to me it's a shame that they dont even know how to steal a car anyways, i think he would have been better off if they did steal it, more money from insurance and brand new car :)
02boostlessVIC is offline
Old 11-30-2005, 01:09 AM   #3 (permalink)
Photobucket
Silver8th's Avatar
There is an easier way to steal cars with key chips. I'm not going to mention, because I don't want anyone getting any ideas. And it doesn't require taking the car apart. If you have ever seen gone in 60 sec you would know?
Silver8th is offline
to the company who decided to steal our design webby 8thcivic.com Site Questions/ Problems 19 11-09-2005 07:23 AM
New Way Theives Steal Gas! - must read webby Water Cooler 1 06-22-2005 09:13 AM
