steam cleaned engine, now its knocking
With the Ohio 8th civic meet coming up I wanted to get the car cleaned up. I got the outside looking good so I thought I would do the inside also. Knowing that water gets the combustion camber sparkling clean, I decided to steam clean the inside of the motor. I drained the oil from the car, put on a new oil filter and filled up the car with 5 quarts of high quality distilled water. I figured the water would remove any crud and grime left in the motor and make everything shiny new. I drove the car for about 45 minutes, in that, I wanted to heat up the water so it would power through any grime. I got home and changed out the polluted water and oil filter. I filled it up with 5 quarts of Mobil 1 and started it up. It knocked so loud my neighbor came over and ask me if I had installed a diesel in the car. Can someone help me? Why is my car knocking so loud? Did I remove too much grime from inside the engine?
#9 (permalink) | |
I've found that Coke is the best thing to clean your engine with. The next best cleaner to fill your engine with is spicy curry.
Try some orange juice - the pulp will fix that knock right up.
![]() search · FAQ · rules · report bad post · learn how to spell Quote:
#14 (permalink) |
Blu I hope this was a joke if it's not PM me and we will get rid on it.. I have been working on car for 14 years .. I own my own Jiffy lube .. I can help you big time.....Number 1 NEVER EVER DO THAT... Water is not a lubricant... YOu should have drained the oil and bought GUM OUT PROFESSIONAL ENGINE FLUSH if you can't buy it contact me I can order it.. anyways Drain oil put the engine flush in with a new oil filter.. run it for 15-20 mins drain out out Flush a Quart of Regular oil through change oil filter and fill up oil with Synthetic...which to tell you the truth do not get scammed into thinking MOBIL 1 is the best it is NOT Pennzoil Platinum is the best Synthetic out there ... I went to classes for these different oils... But Pm and I'll tell you how to fix this with opening up the engine ok .... I'll be happy to help.. you Si Brother.......Sal
#15 (permalink) |
Minister of Discord
Steam clean? You shoulda used brake cleaner, much more efficient!!
• Official BMW 1-Series Thread • DX/LX/EX Gas Mileage Thread • Civic Si Gas Mileage Thread • Civic Hybrid Gas Mileage Thread |
#20 (permalink) |
Ur soul. I haz it.
Disciple of Discord
I still don't get it.
| 2006 Civic Engine: I-VTEC | webby | Garage | 8 | 10-15-2007 11:54 PM |
| Kind of interesting - Honda Chronology 1946-2005 | webby | Water Cooler | 4 | 10-04-2006 09:39 PM |
| civic ex cp engine knocking sound on idle | oplok72 | Civic Coupe And Sedan | 35 | 05-03-2006 10:00 AM |
| 2006 Honda Civic Engine Information | webby | Garage | 4 | 08-04-2005 01:53 PM |
| 2006 honda world news | webby | Garage | 0 | 07-25-2005 09:31 AM |
