Go Back   8th Generation Honda Civic Forum > The Auto Mall - Marketplace - Sponsored Posting > TWM Performance Short Shifters
Old 12-05-2007, 08:18 PM   #1 (permalink)
Spinitch's Avatar
Blue cap
Broke the blue cap while installing the short shifter, any way to get a replacement cap? Do you know where I can find one?
The bushings and the short shifter work great, just the need to cap to finish it off. Thanks TWM
Spinitch is offline
Old 12-06-2007, 01:01 PM   #2 (permalink)
Spinitch's Avatar
any help?
Spinitch is offline
Old 12-06-2007, 03:08 PM   #3 (permalink)
8thcivic Sponsor
Originally Posted by Spinitch View Post
any help?
Sorry for the late reply, I'll send you a PM now with details. We do have some replacements in stock...
Kevin
TWM
TWM Performance is offline
Old 12-10-2007, 10:31 PM   #4 (permalink)
buurner's Avatar
Yes they do These guys are on top of the blue cap breaker crew lol. They are awesome!!!
buurner is offline
Old 12-11-2007, 10:56 AM   #5 (permalink)
8thcivic Sponsor
We've had a couple of customers who have needed these cups recently, so if anyone happens to damage one during the install let me know by PM and I can give you details on how to get a replacement from us.
Thanks,
Kevin
TWM
Old 12-11-2007, 01:59 PM   #6 (permalink)
Spinitch's Avatar
Just a fyi on the replacement white cap. I put the white cap on the SS today and saw that I couldn't get the shifter into 2nd, 4th, 6th and Reverse. I took it back off and noticed that the white cap is slightly thicker on the top than the blue cap, so the shifter arms would stick out a few mm farther and hit the shifter base not allowing to engage into those gears.
Easy fix would be to swap the other blue cap from the left side, put that one on the lower SS nub and put the white cap on the left nub since it wouldn't matter if it was a tiny bit taller since there isn't anything to impede the shifter.
Anyways, it should be all set now. I appreciate the fast response it getting out the replacement cap. Thanks
Spinitch is offline
Old 01-16-2008, 04:52 PM   #7 (permalink)
8thcivic Sponsor
Hi Spinitch,
Thanks for the heads up. We have revised the design of the cup to clear in all gears now.
I'm glad to hear that putting it on the side arm solved your issue.
Also, to prevent damage to the cup we have revised the install manual to clearly show how to use the special tool to remove the cup. Here's the link to the revised manual: http://www.twmperformance.com/manual...all-manual.pdf
All manuals can also be downloaded from our short shifter page here: TWM short shifter
Thanks!
Kevin
TWM
Old 02-19-2008, 05:36 AM   #8 (permalink)
csxian's Avatar
when you shift to gear 2 and 4, does the black cap touch the console (with B marking) there?
csxian is offline
Old 02-19-2008, 06:36 AM   #9 (permalink)
Spinitch's Avatar
Which black cap? The stock caps are blue and the ones I received from TWM were white. The white caps were a tiny bit bigger so they hit on the console in the 2,4,6,r gears.
Are the black caps the newer the revision from TWM?
Spinitch is offline
Old 02-19-2008, 07:54 PM   #10 (permalink)
csxian's Avatar
no no.. The black cap that I'm referring to is the one that holds the blue cap on the transmission lever.
csxian is offline
Old 02-21-2008, 02:08 PM   #11 (permalink)
8thcivic Sponsor
I believe you are referring to the black shifter cable housing that surrounds the blue cup.
Our short shifter puts this shifter cable housing very close to the shift assembly, but it should not make sufficient contact to be be noticeable while shifting.
Thanks,
Kevin
TWM
How does your Civic smell? GeezerSi Water Cooler 170 05-13-2008 08:52 PM
Shifter blue cap Spinitch Bolt-Ons And All-Motor 4 12-04-2007 08:54 PM
Can't get the blue cap off!!! legendman Bolt-Ons And All-Motor 4 10-23-2007 01:01 AM
Check Fuel Cap... Check Fuel Cap... NoMoreHonda Mechanical Problems & Technical Chat 19 09-13-2007 02:16 PM
2008 Colors Available - Civic / S2k / Accord - All Trims cbondhonda New Car-Buying Information 4 07-26-2007 07:07 PM
