Need Help/Advice
So I installed both the TWM SS and the base bushings. Along with the AMSoil synthetic MT fluid I put in, it made all the difference in the world. Awesome to drive now!
However, during the installation of the short shifter, I slightly cracked the blue cap on the end of the linkage ball. It did not break, and it still held on the end of the short shifter assembly, but I was able to push it on and take it off by hand. I ordered a replacement cap from TWM, and while I waited for it to come in, I put the slightly damaged blue one back in as a temporary fix. It drove great, no problems.
When the replacement white cap arrived, I removed the shifter, took the blue cap off, and replaced it with the white cap. Like the instructions said, I had to use a vice to get it on; it was much more secure. So I happily re-installed everything, and test drove it, and then it would not go into any of the bottom gears (2, 4, 6, R). I checked to ensure the adapter was all the way on the shifter, and it was, because there was a mark on the shifter showing where it was previously. Anybody have any suggestions? Is the new cap causing the issue? I had to take the adapter off, and I'm thinking about selling it if I can't figure out a way to fix it. Thanks.
