#102 (permalink) | |
Supreme Pizza!
Sounds fun. Too bad I'm on the wrong side of the border, or I'd see if you'd hire me. ![]()
#103 (permalink) | |
8thcivic Sponsor
It's too bad you're so far away because we are hiring right now, and it is a fun job :) Thanks! Kevin TWM |
#107 (permalink) | |
8thcivic Sponsor
We do offer packages for the 07'-'08 with shifter, base and cable bushings here: 2006-2008 Civic short shifter and bushings. Thanks, Kevin TWM |
#110 (permalink) | |
8thcivic Sponsor
Thanks, Kevin TWM |
#112 (permalink) |
This setup is sick. I have installed the short shifter adapter and the cable bushings under the hood. Rad! I will install the base bushings this weekend. This is a great upgrade as you interact with it every day without having to hit 8,000rpm. Order the whole kit; it installs quick and deliverse a return on investment instantly.
The staff at TWM will help you each step of the way. They have been a huge help and I know they will support any member of 8th to the best of their abilities... TWM FTW. Last edited by VTECnical; 03-07-2008 at 07:02 PM. |
#114 (permalink) |
Just installed everything, had a break in the rain and got it in. My freaking God the shifts are just ridiculous short and tight, it also got rid of the tremble that I had in the shift knob while driving.
FYI if you have a DX, LX or EX the cable bushings are a PITA mainly getting the stock airbox on and off. |
#116 (permalink) |
Get the whole kit man.
Its the gold looking thing with a cotter pin on top, the other bushing is being hidden by the air box ![]() ![]() ![]() If you have any kind of mechanical experience its easy. It was getting the lower portion of the air box out of the car and then back in. In the car with the Base bushings if you have help it gonna come in handy, but you can do it yourself just put the top bushing in first and loosely put the bolt in place and then do one of the corners and then the other and then tighten everything up. Last edited by 07LX; 03-09-2008 at 12:52 PM. |
#119 (permalink) | |
8thcivic Sponsor
Glad to hear everyone is enjoying the short shifter and shifter bushings... We're getting low on stock for the short shifters, but we've started a new production run so we should avoid a backorder situation. Thanks for the orders Kevin TWM Performance |
