Go Back   8th Generation Honda Civic Forum > The Auto Mall - Marketplace - Sponsored Posting > Tire, Wheel, Brake & Suspension Forum Sponsored By The Tire Rack
Click Here
Old 09-26-2007, 07:12 AM   #1 (permalink)
17x8 +35
Will i have any trouble running 17X8 +35 wheels on a stock four door si? How about if i lower the car also. Thanks.
goofyej6 is offline   Reply With Quote
Old 09-26-2007, 07:13 AM   #2 (permalink)
1stk20z3's Avatar
Casey
maybe, i'm sure the corrct offset is +45
1stk20z3 is online now   Reply With Quote
Old 10-16-2007, 01:38 AM   #3 (permalink)
mocsman's Avatar
depending on your tire size. m running +35 offset on 18" rims with 225/40/18 and i was rubbin on every bump. had fenders folded, helped a lil bit but still rubs on huge bumps/sinking portion of roads here in NY. if you'd be on 205s or 215s, i think you'll be safe. lemme know what you decide to go with and tell me if you're rubbing
mocsman is offline   Reply With Quote
Old 10-16-2007, 01:46 AM   #4 (permalink)
SiRyan's Avatar
Are you lowered with camber?
SiRyan is offline   Reply With Quote
Old 10-17-2007, 02:43 AM   #5 (permalink)
krazyguy187's Avatar
lyonel
if you will stay stock, no problem! but if you lower it surefire that you will rub everybump, but you can still prevent it by using 215/40or45 tire size! based on my experience..
krazyguy187 is offline   Reply With Quote
Old 10-17-2007, 02:45 AM   #6 (permalink)
TOMMIELOEKO's Avatar
Location: 15bucks lil man, put that sh*t in my hand!!!!!!!!!!
Shake & Bake!!!!
my neighbor has an EX dropped on some 20inch TIS01s so Idont think you would have problem
TOMMIELOEKO is offline   Reply With Quote
Old 10-17-2007, 02:23 PM   #7 (permalink)
diameter of the rim is not the issue... it's the width and the offset is the main concern here.
8" wide with +35mm offset is cutting it kind of close, especially if you run 225 or wider tires.
shingles is offline   Reply With Quote
Old 10-24-2007, 11:13 AM   #8 (permalink)
CNUco2007's Avatar
Eric
so if you have an 8" wide wheel with a +43 or +45 offset and a 225 tire, you'd be ok?
CNUco2007 is offline   Reply With Quote
17x8 for 215? krazyguy187 Wheel And Tire Upgrades 11 09-04-2007 07:18 PM
question about mix up pair 17x7 with 17x8 pineapple Wheel And Tire Upgrades 24 02-19-2007 08:08 PM
17X7... No, 17X8... No, 17X7... I dunno! i-VTEC Wheel And Tire Upgrades 7 02-14-2007 10:52 PM
