Go Back   8th Generation Honda Civic Forum > The Auto Mall - Marketplace - Sponsored Posting > Tire, Wheel, Brake & Suspension Forum Sponsored By The Tire Rack
Click Here
Old 06-23-2008, 05:12 AM   #1 (permalink)
tire question
Guys, I have a 08 LX sedan and i wanna change my rim to some 17'. as u all know the 08 cars comes with tpms. what i want to ask is can i use 40 series tires for the rims? college honda recommend to use 215/45 series but I wanna use 215/40 series. will it do damage to the tpms/the tpms light will comes on??
please help!!!
artg is offline   Reply With Quote
Old 06-23-2008, 05:23 AM   #2 (permalink)
tire question
Hi,can I use 215/40/17 series tire for my 08 LX civic sedan? will it damage the tpms sensor ( for 08+ cars ) ?? so far I have not see anybody's car in this forum who uses that tire series.
Old 06-23-2008, 09:20 AM   #3 (permalink)
Moderator
iluvmycsx's Avatar
the reason they recommend that size (215 45 17)is it keeps the the same diameter as the stock tires. i believe that it would be fine to use that tire with the tpms but your speddo will be reading incorrectly.
Tire size calculator
My Ride
Toys 4 Tots 2008
iluvmycsx is offline   Reply With Quote
Old 06-23-2008, 09:48 AM   #4 (permalink)
Blktrax's Avatar
Adam
No; going to a lower profile tire will not hurt the TPMS, the guy mounting the tire on the rim might because the lower they are the harder they are to put on.
Any tire manufacturer has their specs listed, you just have to find what works for you, I wanted maximum grip and 100% Speed Accuracy.
http://www.bridgestonetire.com/tires...Specifications
Stock tire: Bridgestone Turanza EL400 or Goodyear GSA
Approved Rim: 5.5" -7.5"
Measured Rim: 6.5"
Overall Tire Diameter: 25.0 "
Section Width: 8.3"
RPM: 833 (Revolutions Per Mile)
BFGoodrich Tires | g-Force? Sport | Tire Sizes & Specs
I went with BFG G-Sports
Approved Rim: 7.0" - 8.5"
Measured Rim: 7.5"
Overall Tire Diameter: 25.0"
Section Width: 8.9"
Blktrax is offline   Reply With Quote
Old 06-23-2008, 10:59 AM   #5 (permalink)
jcxcr4000's Avatar
joel
put a 225 45 on that rim
anything shorter is just going to look odd
jcxcr4000 is offline   Reply With Quote
Old 06-23-2008, 11:51 AM   #6 (permalink)
leftturney's Avatar
Chad
I am running 215/45/17 and using the stock tpms sensors. I wouldn't recommend running 40s though, because your speedo will be off big time. The tpms sensors should be fine but not all wheels support them. Also, if possible, try to limit the weight of your wheels to 19-20 lbs. Anything heavier and you'll only be buying wheels for looks.
Edit: I forgot to mention, if you run 40s, be prepared to put a drop on it, because the gap between wheel and fender will be huge.
Just my .02
leftturney is offline   Reply With Quote
Old 06-23-2008, 09:27 PM   #7 (permalink)
Dustin
is there anything thing on the market that we can use to offset our ecu to read the proper speed with different size tires?
Slipp is offline   Reply With Quote
Old 06-23-2008, 09:53 PM   #8 (permalink)
Blktrax's Avatar
Adam
I know when we do accessory wheels (mostly fot the tpms) that the ecu only takes changes in wheel size, It assumes you're using the reccomended tire size by Honda.
When I changed tires on my Wrangler from 29" to 33", I changed the Speed Sensor Gear, but I havent seen anything like that for these cars.
Old 06-24-2008, 08:30 AM   #9 (permalink)
Smooth Moderator
wing_gundam's Avatar
Civic Type Stock
please help!!!
Please don't create multiple threads on the same topic. Thread merged.
Trying to sell? Read the updated for sale forum rules here
wing_gundam is offline   Reply With Quote
Old 06-24-2008, 04:22 PM   #10 (permalink)
So just to clarify, If I put 07 Si rims on an 08 LX do I need spacers for the front and new TPMS's?? Also, if I use the reccommended 215/45 r17 tires will the speedo read properly and do I have to use honda to do this work?
dmac1998 is offline   Reply With Quote
Old 06-26-2008, 04:32 PM   #11 (permalink)
Old 06-26-2008, 04:33 PM   #12 (permalink)
actually i want to change my rims maybe with SI rims /TSX rims and use 40 series tire, and then I will lower it. Those OEM honda/acura wheels looks good!!!
Tire size vs tire brand pks17 Wheel And Tire Upgrades 1 06-19-2008 12:41 AM
Tire Gurus, Help A Tire Newb Out mattsbobo Wheel And Tire Upgrades 4 04-29-2008 11:15 PM
Nail in tire! Why didn't Honda give the Si a tire pressure sensor? DanH_PsyD Civic SI 19 08-10-2007 05:12 PM
Accutire digital tire gauge - Dirt cheap @ Canadian Tire! SiliconX Water Cooler 9 06-06-2007 12:36 AM
Dunlop Tire Sale - Tire Rack Promotional webby 8thcivic.com Site News 0 06-26-2006 05:48 PM
