Performance Dynamics Reviewed: EX Coupe
It has been about a month now that I've had the new EX Coupe 5MT. To preface, I'm not a tracking-going driver but I'm an avid "driving enthusiast" and consider myself a strong driver on the backroad twisties.
![]() I've been taking weekend drives to get more intimate with the EX's handling, braking and road holding dynamics and this is a review of those areas, based on my experiences within the past 4 weeks. UNDERSTEER Driving a front-drive car, understeer is always a big consideration. Fortunately, it is easily tempered by judicious use of the throttle and is a surprise given the front-biased weight distribution. (60/40; FR/RR). Understeer gets more apparent at low speed, sharper turns than say, a high-speed sweeper. I wouldn't go far as saying that I can induce meaninful oversteer midcorner, but I have been able to rotate the car via left-foot braking and lift-throttle yaw at speed. I haven't driven the Si, but I know that the spring rates, damping rates and roll-rate is increased relative to the EX (which in-turn, is more aggressive than the Civic Sedan.) In particular, based on Shawn Church's review from TOV, the Si's rear roll-bar has a relative 4xx% increase in stiffness than the EX. Still, I'm surprised than the EX handles and communicates road-feedback as with as it does, despite these setbacks. HANDLING DYNAMICS The stock configuration is more set up for a balance of comfort and performance than aggressive driving. The car simply does not like rapid direction changes. There is too much body roll, the rear starts to feel unsettled in a slalom situation and there is too much brake dive & acceleration sqaut. I appreciate the ground clearance but I would gladly trade 1 to 1.5 inches of that to address the areas above. The upside is that the low weight of the car allows you to "throw" the car into a corner at speeds faster than the laws of physics prescribe, only to pull out of a four-wheeled drift with some throttle-action. BRAKES Surprisingly capable. The have a sensitive initial bite and becomes easier to modulate after that initial bite. Strong braking throughout but noticeable brake fade exists in high-speed and downhill driving. At one point, I was driving on a road which twists downhill for about 5 miles and ends in a 100+ mph straight stretch. At the end of the run which concludes with a 100 - 0 mph run, I got out of my car to find the front brakes growing bright red. Most research I've done suggests that rotor surfaces must exceed 1300 deg F for this to happen. On the bright side, despite the fade that occasionally creeps up in intense driving conditions, the brake pressure on the pedal remains consistant even when the rotors are operating at temperatures that should boil the brake fluid over. THE NEXT STEP I feel like I have a good idea of how the car handles - enough to starting thinking about addressing the dynamic weaknesses of the car. They are as follows: [sway-bars] Much stiffer roll-bars, especially in the rear. I hope to drive drive an Si for reference and if that doesn't prove to be aggressive enough (I suspect not,) then I will look to the aftermarket. I have only seen the Progress rear sway to date, and I wouldn't get that unless I had a front sway to keep that balance in check. The Progress rear sway is even stiffer than the Si's. [dampers] More than anything else, the dampers are the performance bottleneck in the EX suspension system. They are simply under-damped because the OEM emphasis is on comfort and not performance. The result is vagueness and sluggish manners. It also creates the sensation of floating, and not a firm contact with the road. [springs] I wish I knew the spring rates for all of the springs out there in the aftermarket for the EX coupe. Most times, manufacturers just list the drop in height. This is good if you want it just for look, but I know that spring rates can really define how the car feels. I need the numbers! Anyway, once I do more reseach, I want to lower the car 1.0 to 1.5 inches to allow the use of a stiff spring rate. That's it for now. This review isn't so much of a review, but me thinking out loud and getting my thoughts on paper, er the web. Feel free to comment or ask question if you have them.
Acorns!
wow that's a nice write up. Do you ever get into autox stuff at all? If you've never taken a stab at it, you may really enjoy doing some at some meets/weekend get togethers. As far as brake fade - I know a few members have already updated their pads to hawk or other brands which they said had a significant improvement in performance and brake fade issues. - less brake dust as well with some brands.
the spring rates can be seen below as far as helping you out a bit. SI spring rates: Front 200 lbs. / inch Rear 230 lbs. / inch This means that the DX, LX, and EX Coupe rates are approximately: Front 170~175 lbs. / inch Rear 200 ~ 205 lbs. / inch This is taking into account the Si front rates are listed by Honda as being 17-18% stiffer and the rears are 14-15% stiffer than regular Coupes. And obviously there is the ability to swap out the SI sway bars as well which are much thicker. again - nice writeup. |
#4 (permalink) | |
Regarding fitment, I believe everything fits between the EX and Si. For now, even if better pieces come out of the aftermarket, I want to swap my suspension out for the Si's. It seems too early in the 8th gen life cycle to put too much focus on aftermarket parts. Si's suspension is proven and I know it works. All else equal, an EX with the Si's suspension will theoretically out handle the Si with OEM suspension because the EX is lighter by a couple hundred pounds or so. I don't have the LDS that Si's do, but that's another issue entirely. Last edited by gbae007; 06-25-2006 at 07:41 PM. |
#5 (permalink) | |
Acorns!
#6 (permalink) | |
Thanks Webby. Do you know if there is a relative ride height drop going from the EX to Si springs? I also wanted to point out that the EX is lighter by a small margin vs the Si, so the stiffer spring rate in the Si's isn't a completely linear % increase when used on the EX. |
#7 (permalink) | |
Acorns!
ex 2701 manual weight si 2877 manual weight I don't know about ride height change going from ex to si springs only. I know a few members have bought the SI springs - they might be of help. |
i have a sedan, but i can surely agree to the 'floating' feeling you described.
the rear toe is set too mildly as if it's already at zero toe for tire wear and fuel economy reasons... the rear wanders a tad when one side of the car goes over a bump. this unsettling feel was apparent on not only my EX sedan, but on other 06 civics. When i do finally lower the ride down the road, i would set the rear toe to about 0.10 to 0.12 degrees each side. this should minimize the rear floating/shifting feel. anyone know the factory rear toe setting? thanks. |
I'd recommend purchasing 17" wheels with 215/45-17 tires and the Si front and rear sway bars before doing anything with the springs. It might just give you what you're looking for without having to sacrifice too much ride comfort by going with stiffer springs. The vagueness that you attribute to the dampers can also be caused by the flexible tire sidewalls and the relatively flimsy sway bars.
Check this out: Si Front & Rear Sways on an EX Sedan |
#10 (permalink) |
Or instead of upsizing the wheel size, you might consider just getting wider, lower profile tires (225/50-16) and keeping the stock rims. You might run into problems with the sidewalls bulging out though, since the stock rims are only six or six and a half inches wide.
#11 (permalink) | |
#12 (permalink) |
Okay, I've got a question that I can't find an answer to:
What are the HFP springs and dampers rated at? There are HFP kits ($600 at College Hills) for the Si, the coupe and the sedan. I've got a sedan, and I'm wondering how stiff (harsher ride) the HFP springs and dampers would be? Sounds like an Si rear roll bar on the sedan would be a good move. Si Front & Rear Sways on an EX Sedan |
#13 (permalink) | |
Regarding the tires, 225 would not safely fit on a 6.5 inch wide rim. (That's the EX 16" rim size.) |
#14 (permalink) | |
An EX front sway with an Si rear would be too mismatched I feel, and iVTEC has confirmed this in his writeup. Si Front & Rear Sways on an EX Sedan |
#15 (permalink) |
Great write up. I've found that upgrading the wheel/tire combination to an Si wheel/tire set-up improves the handling even more without sacrificing the ride quality one bit.
I think the bigger Si rear bar would lessen the understeer that is common with the FWD platform. The Si sway isn't that much bigger then the EX one. |
#16 (permalink) | |
#17 (permalink) | |
I guess it comes down to what you're looking for. I personally wanted a car that didn't wander (that vague feeling that the thread starter described), stayed flat in the turns, and gave me a feeling of confidence and connectedness to the road. I don't auto-x or race. I do enjoy curvy country roads and taking sweeping freeway on/off ramps at 20+mph over the stated speed limit. Sorry, just the rear Si bar didn't do the trick for me. I didn't get that feeling until I put both the Si front and rear sways in. Now the thought of the 22mm Progress rear and the Si front... now that sounds appealing. But that will have to wait until later. No $$$ for that at the moment, plus I'm loving the car as-is. Good luck whatever you decide to do. Last edited by iVTEC; 06-26-2006 at 10:16 PM. |
#18 (permalink) | |
This would be a truly stealth mod. Good luck. |
#19 (permalink) |
Another random thought. I think some members of this forum are selling their Si suspensions. You might consider getting one for an OEM upgrade. Do a write-up so that we can all benefit from the experience. Add to collective body of knowledge and all that.
I don't know if the aftermarket has dampers out yet. I know there are some spring sets. |
#20 (permalink) | |
| how much of a pig is your car? weight list | webby | Garage | 20 | 05-01-2008 02:30 PM |
| civic ex coupe or si? | matta | Introduction & Pictures | 45 | 02-28-2008 05:38 PM |
| DIY LED in EX Coupe AT w/ no foglights | reelbigfish241 | Do It Yourself Articles | 2 | 06-01-2006 11:53 AM |
| OTD Price for EX Coupe W/NAVI | pnamdiggity | Civic Coupe And Sedan | 5 | 05-10-2006 06:43 PM |
