Old 06-20-2006, 08:39 PM   #1 (permalink)
Moderator
sickyute's Avatar
Marvie
Hawk HPS or Axxis Ultimate Ceramic
so which would u go with and why?
Shift when it blinks!
Old 06-20-2006, 09:34 PM   #2 (permalink)
MaKo's Avatar
I can only speak to the Hawk HPS pads. Never tried the Axxis. Have been using the HPS pads for a couple of years now on different vehicles and they are a vast improvement over any OEM's I have seen from Honda, Toyota, or GM. You will note a definite improvement in stopping power and fade. Dust build up is lower also. These pads are pretty quiet also, which to me is a big plus. I hate squeaky brakes with a passion.
MaKo is offline   Reply With Quote
Old 06-21-2006, 02:34 AM   #3 (permalink)
larryd's Avatar
Well I sell both so let me tell you what I would tell any other customer.
Hawk HPS - This is what 90% of our customers purchase for all kinds of applications be it 400hp cars or 4 ton trucks :)
Axxis Ultimates - We don't sell very many of them but IMO they are the best pad on the market. I ran them on my Integra along with Power Slot rotors and the braking was improved what seemed about 200%.
So to compare them... The HPS pads being semi metallic will give you less brake dust then the Axxis Ultimates as the Ultimates are a Ceramic/Kevlar mixture. I seriously have never had a dustier pad then the Axxis Ultimates as they turned my bronze wheels black on a daily basis. The Ultimates will give you better braking as they have more tolerance to heat soak. I ran the pads several times up to 100 and back to 0 with no brake fade whatsoever. The Hawk HPS pads will have alot of tolerance but they would give out before the Axxis pads would. Lastly would be the life expectancy; The HPS pads should outlast the Ultimates by a pretty decent amount was once again the metallic pad will wear less then the ceramic pad.
Either way, you can't go wrong :)
larryd is offline   Reply With Quote
Old 06-21-2006, 03:21 AM   #4 (permalink)
Acorns!
webby's Avatar
^^^ great post
webby is offline   Reply With Quote
Old 06-21-2006, 10:14 AM   #5 (permalink)
Fixer's Avatar
Esteban
Was indeed a great post. Said quite a bit in few words. Thanks for the info.
Fixer is offline   Reply With Quote
Old 06-21-2006, 10:47 AM   #6 (permalink)
2RotorMotor's Avatar
Awesome, thanks for the review.... Im going with HPS pads...
2RotorMotor is offline   Reply With Quote
Old 06-21-2006, 03:33 PM   #7 (permalink)
Moderator
sickyute's Avatar
Marvie
So no that this is taken care of....06 Si owners should be aware that we share the same brake pads as the RSX type S and the S2000. if u want an upgrade go ahead and get those...
they fit...
Old 06-21-2006, 03:40 PM   #8 (permalink)
they fit...
I thought it was only the fronts??
Old 06-21-2006, 04:24 PM   #9 (permalink)
Moderator
sickyute's Avatar
Marvie
if the fronts fit then the rear should also.
i'll go get some at pep boys...hopefully they have them in stock and i'll let yall know.
Old 06-21-2006, 04:48 PM   #10 (permalink)
what brakes do they have at pepboys? the hps?
Old 06-21-2006, 04:52 PM   #11 (permalink)
Moderator
sickyute's Avatar
Marvie
yea i went to hawk's site to look for vendors in my area...and the majority that came up were pep boys...like 20 of them and murrays speed and custom.
they should have all the hawk pads...hps, hp plus and ceramic.
Old 06-21-2006, 05:03 PM   #12 (permalink)
ok thanks...
Old 06-21-2006, 05:10 PM   #13 (permalink)
larryd's Avatar
Actually most Pep Boys don't carry the HP Plus or HP Ceramics only the HPS and generally they keep low stocks but can order them to have them in a day or two.
Old 07-31-2006, 12:44 PM   #14 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
anyone ever find out for sure if the rsx or s2000 pads fit? I checked part numbers and they are all different so i was just wondering what the outcome was.
Old 07-31-2006, 01:10 PM   #15 (permalink)
The rsx pad WILL fit ours... I bought a set of rsx pads last week and installed them, apparently most chains don't have the si in their catalogs yet..
Old 07-31-2006, 01:47 PM   #16 (permalink)
Tuna Fiddle™
Dave
ok thats good to know b/c I was checking part numbers and the only ones that match are the rear pads. I guess the front are the same size just a different material or something. BTW does it matter RSX s vs the base model RSX?
Old 07-31-2006, 01:49 PM   #17 (permalink)
Moderator
sickyute's Avatar
Marvie
i bought RSX-S...and they fit...front and rear.
Old 07-31-2006, 03:02 PM   #18 (permalink)
I got the type-s...
