Old 05-07-2008, 10:41 PM   #1 (permalink)
SPC Rear Camber Adjusters
hello everyone
quick question.
i lowered my Si 1.5" with MEGAN springs.
i was looking around to look for camber kits, and came across
these "SPC Rear Camber Adjusters".
can i get these instead of buying the camber arm kits??
(can save myself a bill)
it says:
* Perfect for stock ride height and LOWERED cars!!
* Amazing SPC Quality cannot be beat!
* Improves handling on wet and dry conditions
what do you guys think???
thanks
justphuta is offline
Old 05-07-2008, 11:28 PM   #2 (permalink)
I haz da Taffy's
Nomar06's Avatar
Do you have a pic of the "SPC Rear Camber Adjusters"? As far as I know, SPC only has camber arms for the rear and camber bolts for the front.
Nomar06 is offline
Old 05-07-2008, 11:43 PM   #3 (permalink)
Old 05-07-2008, 11:45 PM   #4 (permalink)
Old 05-07-2008, 11:49 PM   #5 (permalink)
ovur ur headz
Qshooter151's Avatar
Jordan
link?
Qshooter151 is offline
Old 05-07-2008, 11:57 PM   #6 (permalink)
nelsonr31's Avatar
Originally Posted by justphuta View Post
Since when did this come out? Link? I have SPC rear camber kit on my car already and that's just the brackets that came with the kit?
nelsonr31 is offline
Old 05-08-2008, 12:55 AM   #7 (permalink)
eBay Motors: SPC REAR CAMBER KIT HONDA CIVIC SI LX EX 06 07 08 (item 160238110905 end time May-13-08 20:27:39 PDT)
Old 05-08-2008, 04:08 PM   #8 (permalink)
nelsonr31's Avatar
Cool, The full rear camber kit adjusts -/+ 3 Degrees, These Adjusters go -/+ 1.25 Degrees and retain your stock upper control arm, not bad of an idea.
Old 05-08-2008, 04:12 PM   #9 (permalink)
NIGHTHAWKSI's Avatar
Ian
i dont see how this will work. what are you goign to use as a camber arm? the OEm will not fit into that bracket....
NIGHTHAWKSI is offline
Old 05-08-2008, 04:19 PM   #10 (permalink)
nelsonr31's Avatar
You'll use the oem arm but first press out the rubber bushing then press in the new bushing that is in the above picture.
Old 05-08-2008, 04:20 PM   #11 (permalink)
Ian
o0o0o, i see. great idea by SPC to release this.
Old 05-08-2008, 04:25 PM   #12 (permalink)
nelsonr31's Avatar
Alot cheaper too
Old 05-08-2008, 05:37 PM   #13 (permalink)
so do you think -/+1.25 is good enough for a 1.5 drop??
also..i checked out the instructions for installing this at the SPC website. . and it says i also need to buy the PRESS TOOL*. . .
is this a must to install these adjusters?
Old 05-08-2008, 08:01 PM   #14 (permalink)
Knowing how much camber can be adjusted with this setup would be awesome. Any insight fellas?
Thanks!
lush is offline
Old 05-08-2008, 08:45 PM   #15 (permalink)
ortivt6's Avatar
Ant
those work with the OEM rear arms...
ortivt6 is offline
Old 05-09-2008, 12:08 AM   #16 (permalink)
Thanks!
-/+ 1.25
so do you all think thats enough of an adjustment for my 1.5 drop?
Old 05-09-2008, 12:15 AM   #17 (permalink)
sh33t_0f_p4p3r's Avatar
Tobie
damn, thats cool, anyshop should have a press tool
sh33t_0f_p4p3r is offline
Old 05-09-2008, 12:21 AM   #18 (permalink)
nelsonr31's Avatar
-/+ 1.25
I think it should be fine.
Old 05-09-2008, 02:57 AM   #19 (permalink)
Thanks alot fellas for the comments...
think im going to save a bit and get these. . .
good to know i wasnt the first to find out about these. . ..
SPC Rear Camber Adjusters BigMoney8481 Suspension and Brakes 0 04-07-2008 07:52 PM
