#41 (permalink) |
From what I understand from conversations with component manufactures, it's basically a CYA thing. Cover your ass. The stampings have already been ISO tested and crash certified. Since the strut is a piece of the suspension and not just a dampening device (the Mac strut IS the upper control arm), if it were to fail at any speed could turn into a nasty corporation ending lawsuit. If you "lease"/buy the stampings, you are basically buying the struts and modifying them for their own use (painting and re-packaging) so they do not require re-certification. If you developed your own for "street use" is required by DOT to have them certified and tested. If you specify a "not intended for street use" label, it stil requires testing, but if it fails, the consumer is SOL if it failed on the street. Most race parts are tested at way higher standards than DOT but manufactures do NOT want to go through the ahslle or red taoe to get the DOT approvals. I can't really say I blame them ater seeing how long or a process it is.
Jeff Last edited by jasyatz; 06-10-2008 at 03:15 PM. |
#43 (permalink) |
My understanding is that Koni is going with full replacements. I can get in touch with CRX_Lee if we need more info, but I think some other members have already confirmed it. IMO, simple inserts would have been available by now. Related link: Konis still a ways out |
#44 (permalink) | ||
Louder than 4 F404-GE-400
You know what the sun's all about when the light go out. |
#46 (permalink) | |
#47 (permalink) |
I write like I think...Short detailed thoughts strung together by a shoestring sputtered out as fast as I can type them so I don't forget anything.
Sorry if it was tough to read. It was tough enough to write..You should see me text, it's downright painfull!! Jeff |
| HID + Luminics JDM Yellows PIC UPDATE!! | imdanchu | Lighting, H.I.D.'s, & Neon | 23 | 03-04-2008 04:33 PM |
| Koni Yellows + (Insert random springs) = Ok? | I Vtec, do you? | Suspension and Brakes | 5 | 02-18-2008 05:46 PM |
| Koni FSD or Koni Coilover kit | zspeedzkwy | Suspension and Brakes | 8 | 01-03-2008 04:51 PM |
| Looks like Koni "Yellows" are available... | CaliGuy | Suspension and Brakes | 4 | 07-15-2007 03:40 PM |
| What shocks beside the Koni yellows are in development? | Blk4drSI | Suspension and Brakes | 10 | 05-11-2007 05:39 PM |
