Modded LX Vs Stock Si?
I'm looking to see what people think on which car will handle better, a lighty modded LX or a stock Si. I am only referring to cornering ability here, i know the Si will be able to enter and leave corners faster due to its engine and brakes. Lets also assume both cars will be fitted with the exact same wheels and tires.
Car 1. Civic LX with HFP suspension and Si front and rear sway bars. Car 2. Civic Si - 100% stock. Thoughts? |
With what you listed as the setup, the SI, but i feel in an auto-x course the LX will have the advantage due to lighter engine, and no sunroof, and lighter weight car. It would also have to be set-up on a good suspension, and the SI would have to be stock.
![]() ![]() ![]() ![]() ![]() BUILD MY CITY!:http://whocares05050.myminicity.com/sec http://whocares05050.myminicity.com/ind
Is the HFP suspension for the LX really that mild compared to the stock Si spring/strut combo or is there chassis reinforcements on the Si or other things that give it the edge? I would think that the LX being 250+ lbs lighter would be a considerable advantage.
Good info, keep it coming! |
Lets see, first of all the LX has drum rear brakes which will greatly decrease the corner entry. Second, the fact that the SI has an LSD will greatly effect it's corner exit speed. So in both corner entry and exit, the LX will loose. Third, the SI has a close ratio 6 speed transmission which will greatly increase it's acceleration out of the turn (not to mention the added power). The only thing the LX has going for it is it's lower weight, even the hefty 229lbs will not make up for the lack of braking and LSD.
This is assuming both have the same set of tires. Last edited by habitat; 05-07-2008 at 04:33 AM. |
#10 (permalink) |
I read the first post. I think in certain racing conditions the SI will loose.
#12 (permalink) |
Louder than 4 F404-GE-400
Lx + HFP > Si especially on an auto x course.
The thing about an auto x course is, it’s too slow for the Si to always be in VTEC. 15-60 mph is about the range of speed on an auto x course. The Si will hardly get out of 2nd gear on most auto x courses. So anything below 37 mph, the Si will be off the big cam at which point the power difference between the Lx and Si is negated by the weight difference. Furthermore, the Lx is only down 10 lbs ft of torque to the Si and its torque peak is 1800 rpm lower than the Si. If you do a torque to weight ratio of the Lx to the Si (because torque matters more on the tight confines of an auto x course) the Lx has to pull 20.59 lbs per foot lb of torque, where the Si has to pull 20.76 lbs per foot lb of torque. Also, the Lx can do over 60 in second so it will not require a time wasting up shift to 3rd and down shift back to second. The Lx + HFP will own in the corners. 229 lbs is a lot of weight to have to change direction. Also, the LX has a lower Cg and better weight distribution than an Si so those will help increase cornering speed. The LSD in the Si sucks. It does just enough to keep the inside wheel from spinning. Since the Si will be out of VTEC most of the time, there will not be enough power to activate the LSD anyway, so what little advantage it has is negated as well. Brakes don’t stop a car, tires do. Since both cars will have the same tires, both should have equal braking performance. Regardless of the fact that the Lx has rear drums, it can still lock the tires up. That means that the brakes have more power than the tires can handle. This means that both the Si and Lx will have to do threshold braking in order to keep the tires from locking up and losing time. Once again, the 229 lbs weigh difference will also negate any braking advantage the Si might have. On a road course however, Si>Lx + HFP. There is not enough of a difference in handling for the Lx to make up the 57 hp difference. In conclusion, the Lx + HFP will out handle an Si with ease and should beat an Si on an auto x course.
Waking up dead inside of my head will never never do, there is no med, no medicine to take. I've had a chance to be insane, asylum from the falling rain. I’ve had a chance to break. |
#14 (permalink) | |
An Lx with HFP + an Si rear sway bar would be a hoot in the twisties.
#16 (permalink) | ||
Here are Revy's and my explanations of the harm an lsd can do. We are not saying lsd's are all bad and pointless, just saying they can make a car slower if not used/set up properly
#20 (permalink) | |
A thicker sway bar improves turn in by resisting weight transfer. It loads the outside tire quicker so you don't have to wait as long for the body to roll over, push down on the tire, and create the amount of friction needed to get the car pointing in a different direction. The down side of this increase in initial friction (traction) is there is less friction to help accelerate the car coming out of the corner. So you wanna gain a 10th going into the corner or 5 10ths coming out? Your call.
