#24 (permalink) | |
So according to your theory an LX with a K20 swap would handle better than the Si assuming it had Si struts/springs? |
#25 (permalink) | ||
Louder than 4 F404-GE-400
Also, you missed the word "can" as in "an lsd can cause throttle induced understeer." Also, Motortrend and Car and Driver test street car with the average buyer in mind. Revy and I are far from that. Both Revy and I said that it can help on corner exit. Quote:
This thread posed the question of "Can a Lx with an upgraded suspension out handle an Si?" Yes, yes it can.
You know what the sun's all about when the light go out. Last edited by Sirbelch; 05-10-2008 at 03:06 AM. |
#26 (permalink) |
To add to what I said, Honda makes the Si for the masses. They have to make compromise at every turn. How do you get a car to have good turn in and a good ride, you put a fat front sway bar on. Big fat sway bars in the front can reduce total front grip. Evn though this is a little of topic but, how do you keep the power hungry people and the EPA happy at the same time? Make a 250 hp engine make 197 hp.
I blew my straight line budget trying to find a suspension that works because I feel Honda didn't give me what I wanted. My 4th suspension (including stock) will be here in two weeks. That's the kind of handling junkie I am.
You know what the sun's all about when the light go out. |
#28 (permalink) | |
Wisdom dSLR Squad #76
#29 (permalink) |
You want to reduce the front bar and increase the rear bar to help rotation.(Get sedan LX bar/progress rear sway) The LX body is the same.
The sedan front bar might not be worth it though..its only a 1mm difference. Front Bar Size 4DR DX, LX, EX: 24.2mm 2DR DX, LX, EX: 25.4mm 4DR Si: 27mm 2DR Si: 28mm Last edited by friedk; 05-10-2008 at 03:52 AM. |
#32 (permalink) |
thanks! that was really helpful. so just a progress rear sway and leave the front alone right? HFP suspension is coming soon along with custom alignment/camber kit.
#39 (permalink) | |
Robert
#40 (permalink) |
Si is 61/39 Lx is 60/40. Although 1% doesn't seem like much, the Si carries 1760 lbs over the front wheels while the Lx only carries 1594 lbs. Thats a 166 lbs difference.
| Modded Si vs. Stock Si and Sportbike! | civicracer32 | Water Cooler | 13 | 03-19-2008 12:52 PM |
| Progression of rides...Stock to modded' (not 56K friendly) | berlinas2k2 | Water Cooler | 29 | 06-23-2007 12:39 AM |
| First pictures since it was stock, slightly modded NHBP now | BSchuster | Introduction & Pictures | 15 | 04-01-2007 10:11 PM |
| Stock Navi modded to DVD player? | Liu | I.C.E., Electrical, Security, & Navigation | 2 | 02-22-2007 06:25 PM |
