Old 05-03-2008, 12:12 PM   #1 (permalink)
Stylinhonda's Avatar
Stephen
T1R B Max Coilovers!
Just got my T1R B Max Coilovers yesterday. After waiting about a year for the Koni Yellows to come out, they still havent come out, so I ended up waiting for these.
There a 46mm piston monotube design. 36 way compression and rebound adjustable. The spring rates are F.8k R.6k.....so I might switch them out for some Swift springs later on. Has the front camber adjusting uppermounts for negative camber adjustments up to -5 degrees (don't have a clue on how to adjust that.)
Stylinhonda is offline   Reply With Quote
Old 05-03-2008, 12:13 PM   #2 (permalink)
nevertofast's Avatar
damn those look beautiful!!! how much ?
nevertofast is offline   Reply With Quote
Old 05-03-2008, 12:17 PM   #3 (permalink)
jrotax101's Avatar
Robert
If looks won, i woulda got those over pro-c's haha. they would go on a fiji very well.
btw, good luck with those instructions, they look slightly japanese :P
Next Project : E36 M3 boosted track car
fawk.. if my volks were hyperblack/formula silver.. my ballz would jump out and blow my pee pee
jrotax101 is online now   Reply With Quote
Old 05-03-2008, 12:20 PM   #4 (permalink)
Stephen
Ha yeah they look crazy! They will go well with my Mag Blue's......once they come! Yup there is not one letter of english on there. Yet it shouldent be to much different than any other coilover setup for the FG2. Plus I'm sure T1R could always help out with install questions!
Old 05-03-2008, 12:30 PM   #5 (permalink)
jrotax101's Avatar
Robert
yeh, coilovers are a simple install. :)
Old 05-03-2008, 12:36 PM   #6 (permalink)
Stephen
Yet I have never installed coils on a new civic....with the rear springs seperate from the struts.
Old 05-03-2008, 12:58 PM   #7 (permalink)
whitecivicsi's Avatar
It's actually not hard at all bud. Just remember what you take off. and remember to put it back on.
whitecivicsi is offline   Reply With Quote
Old 05-03-2008, 01:11 PM   #8 (permalink)
jrotax101's Avatar
Robert
just put the bucket spring in first then put the bolt through the mounting point in the rear strut and you're all set, you shouldnt need to undo the sway bar, unless you have a progress one.
Just push down on the rear arm to get the oem spring out
Old 05-03-2008, 02:08 PM   #9 (permalink)
8thcivic Sponsor
AJR Joey's Avatar
Looks great! Enjoy them :)
A&J Racing International / Type One Racing International
#11-12840 Bathgate Way
Richmond B.C.
Canada V6V 1Z4
TEL: (604)279-0329
URL: www.aj-racing.com www.typeoneracing.com www.jsracing-net.com
AJR Joey is offline   Reply With Quote
Old 05-03-2008, 05:15 PM   #10 (permalink)
ebphoto's Avatar
Evan
youll love them..
just make sure your dampening adjustment works though... we got one of my rears on and it wouldn't adjust.. they sent replacement bodies, i just need to install them.
the fronts went on no problem, but for the backs i was definitely glad i had access to a lift..
ebphoto is offline   Reply With Quote
Old 05-03-2008, 06:22 PM   #11 (permalink)
Impreza_22B's Avatar
omg i can't wait until this coming friday to receive mine.
Impreza_22B is offline   Reply With Quote
Old 05-03-2008, 06:30 PM   #12 (permalink)
CivicSi907's Avatar
Thomas
looks nice!!! how much did you pay for?
CivicSi907 is offline   Reply With Quote
Old 05-03-2008, 07:43 PM   #13 (permalink)
Louder than 4 F404-GE-400
Paul
Oooooooooooohhhh a sparkly.
Once you get it on the car, you will see how the front adjust camber. Undo the bolts on the plate, slide the top of the strut towards the center of the car for negative camber, slide it away for positive camber.
Don't go to low. The front suspension geometry doesn't like more than 1.5in.
Sould be plenty smooth on the streets with 8k/6k f/r
Old 05-03-2008, 09:02 PM   #14 (permalink)
Stephen
Yeah the camber seems easy enough. Guess I will figure it out! I think I'll want to go stiffer, my last GC and Yellow setup was much stiffer, felt great on the track and street!
Old 05-03-2008, 09:26 PM   #15 (permalink)
Paul
Thats more a product of the dampers than the springs. "JDM" suspension tuning uses lots of damping to make up for "softer" springs. They have smoother roads, so they can get away with it.
Old 05-05-2008, 12:17 AM   #16 (permalink)
In for feedback.
Afrikantk is online now   Reply With Quote
Old 05-05-2008, 10:07 PM   #17 (permalink)
Stephen
Blah, Koni took forever, so I thought why not give these a try. Our roads don't really suck here. There not great but not horrid. I think I'll wait till I get the Tranny TSB done before I put these on.
Old 05-05-2008, 10:27 PM   #18 (permalink)
FA5VL's Avatar
so im limited to 1.5, can you explain what actually happens if i go beyond 1.5inch?
FA5VL is online now   Reply With Quote
Old 05-05-2008, 10:39 PM   #19 (permalink)
Paul
Front lower tie rods go inverted causeing a lot of understeer. The roll center of the car moves up causing more body roll for a given amount of suspension travel. You lose suspension travel. Bump steer happens.
Old 05-05-2008, 10:43 PM   #20 (permalink)
dt07Si's Avatar
Dave
Nice purchase!
dt07Si is online now   Reply With Quote
T1R Power Header, T1R 70R Exhuast New Dyno !! AJR-CoW Bolt-Ons And All-Motor 49 11-11-2008 03:01 PM
BC Coilovers or Megan Racing Coilovers? CivicSi907 Suspension and Brakes 32 04-29-2008 09:24 AM
Z max anyone try it? fatality122887 Mechanical Problems & Technical Chat 6 10-22-2007 07:49 PM
!! COMING SOON T1R B52 Coilovers !! AJR-CoW Suspension and Brakes 19 07-11-2007 03:44 PM
