#61 (permalink) |
The front Si sway bar (and rear bar for that matter) are heavier. I don't think it's enough to make a difference in gas mileage. It's maybe 10-15 lbs more total for the two bars.
What's more of a concern is the weight of the Si wheels. They weigh 23.5 lbs according to my bathroom scale. That's rotating mass that tends to decrease acceleration and braking. I do like the handling improvements, though, of the upsized tires. I just wish it cam in a lighter package. I will say that the handling is almost comparable to my RSX-S now that I have the Si bars, wheels and 215/45-17 tires. My RSX-S had the A-Spec suspension, neuspeed front strut tower bar and progress 22mm rear sway/tie bar plus energy suspension front sway bar bushings. I would suggest for the more aggressive driver to consider getting the rear Progress 22mm bar instead of the Si rear sway to go with the front Si bar. I'm considering it for some time in the future. Last edited by iVTEC; 08-13-2006 at 11:10 PM. |
#64 (permalink) | |
#67 (permalink) | |
#70 (permalink) |
Finished about an hour ago then cleaned up and took it for a spin.
Man, that feels great! The weight difference of the bar itself from stock to the Si's is incredible. Now I just need to put my Si shocks/dampers on (they go on first friday of sept.) with my Tein s-techs and my car will be a beast. Great upgrade, I highly recommend it |
#71 (permalink) | |
Glad you like the upgrade! I bet you'll really be able to hug the turns with the S-techs and the Si dampers. How do you like the S-techs? Do they ride much rougher than the stock EX springs? Thanks |
#72 (permalink) | |
What I'm curious to know is: 1) How much different is SI shocks compared to EX sedan/coupe 2) Are they just stiffer to accomodate weight? Is so, would there be an increase in performance or just a harsher ride? 3) How different is the HFP SI and HFP EX suspension? Would getting HFP SI suspension make a difference?
#73 (permalink) | |
#74 (permalink) | |
#75 (permalink) | |
What i'm referring to specifically is using the SI HFP kit instead of the EX HFP kit. |
#78 (permalink) |
I finally got the time to install the front sway bar, so here's my impression and some install tips.
Installation - Get the front end off of the ground and secured (use jackstands, set the ebrake and block the back wheels, I know I'm paranoid, but I like the current shape of my head and don't want it altered to resemble a crushed watermelon) - Leave the key in the ignition on accessory so that you can steer the front wheels by hand. - There's two pinch bolts, one on each end of the endlink. I removed the one attaching the endlink to the A-Arm since it was easy to get to when you steered in each direction. - To remove the pinch bolts, use an allen wrench to hold the bolt while you remove the nut with a 14mm box wrench. You may need to spray some liquid wrench on them to loosen them up a bit. My car is only 9 months old and they were pretty tight. - Remove the bracket bolts and remove the sway bar. - Remove the endlinks and move them to the new sway bar. - Lift the sway bar in place and hand tighten the bracket bolts. - Get the pinch bolts back in place and hand tighten the nuts. - Tighten everything back up - Put her back on the ground and enjoy! Driving Impressions I did the rear sway bar several months ago and loved the results. Adding the front really completed the picture. I agree with everything in iVTEC's original post, the front end feels way more planted and it doesn't induce any more understeer from what I can tell. I can push the car harder into a corner and it feels like I can alter my line a little easier. I really couldn't feel any discernible change in ride quality with either sway bar. I'm going to get out and push it a little harder over the course of the week and I'll follow up if I notice anything different. |
#79 (permalink) |
Shesh, you guys stop torturing me, haha.
I havne't got my civic ex in yet and you guys are talking about upgrading the strut and sway/what nots to make it to SI like or better. I will have to see though since my intention on this baby is pretty much all commute, luxery and daily but the price isn't bad for a nice suspension upgrade. STOP!!!! haha |
#80 (permalink) | |
Hurry up and go shopping!!! |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/9328-si-front-rear-sways-ex-sedan.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-19-2008 11:44 PM | |
| Help me with my rear sway bar 2006 CSX - Page 2 - Acura CSX Forums | This thread | Refback | 01-14-2008 11:38 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-11-2008 06:15 PM | |
| Dumb Laws | C2i0v0i1c | Water Cooler | 58 | 10-03-2008 10:27 AM |
| EX Sedan 60/40 Split rear seats | 8civic8 | Civic Coupe And Sedan | 7 | 05-03-2006 09:57 AM |
| 2006 Civic Summary from Temple of VTEC | shoptb | Driving Experience | 4 | 01-11-2006 03:40 AM |
| 2006 Civic sedan rear window | clm10k | Civic Coupe And Sedan | 5 | 01-07-2006 04:23 PM |
