#203 (permalink) |
I still feel that unless you are driving at the limit, having both makes the car much more solid and controlled while still feeling fairly neutral. The setup must be fairly well balanced if it comes from Honda on the Si! If you are tuning for oversteer, then by all means stick with the rear, or put the Si sway on front and a thicker aftermarket on the rear. For my normal daily "spirited" driving, having Si front and rear has worked really well.
This thread could go on forever........... |
#204 (permalink) | |
#205 (permalink) |
sways
i agree with tegrady.. i put both on mine, and quite enjoy the balanced feel.
initially, i only installed the rear one (it was easier with my jack/ramps) and drove for about a week on it, and found it made quite a difference. it was such a thrill to 'feel' the rear end respond when i threw it into a high-speed corner (again, nothing stupid, just spirited driving). once i put the front in, it wasnt as dramatic a difference, but definitely felt more planted in the front, especially if corners were going to be bumpy.. imo, for the money you spend, its a cheap upgrade, and doing both really makes me appreciate my car that much more! |
#206 (permalink) | ||
THe thread shouldn't go on for ever, there are facts to tuning a suspension. If you want to be faster and more confident then there are things that work and there AREN"T. While maintaining the stock front sized bar and increasing the rear the car is still controll. Quote:
If it did anything it gave you a less balanced feel even more heavily biased towards the front of the vechile. As far as it feeling more planted over bumpy surfaces that is an ABSOLUTE falsity.... "Let me start with the higher the suspension frequency grip decreases. SO WHAT? Well this frequencey is a measure of how many cyles per minute or in a second, the car would go through and bounce up and down on springs alone. This matters greatly to you because the stiffer the suspenion is the less contact pactch will be touching the ground over rough surfaces, and if the tires in the air your not gaining traction or grip. The more grip your tires can make, the more force your putting into the car so you will need to up the resistance to body roll to keep it at an acceptable level. Race tires need a much stiffer suspension than a street tire. Cause their grip is that much higher and will cause the body to roll, losing camber and reducing grip. In simpler terms...you want to run the softest springs you can get away with that reduces body roll to an Livable level, and has an approperate roll couple balance to give you the oversteer/understeer charateristics you want with the most grip your car can achieve." |
#207 (permalink) | |
I thought I was pretty clear that all of my statements were based on feel (Butt-Dyno) and I don't Auto-X or drive close to the limit. You're acting like it's a completely idiotic move when it's not. It's not like we're talking about a $2,000 mod that's going to ruin the car. My opinion is to spend the $200 or less and see how you like it with each setup. If anything, you remove the front and you're out $80 that you can probably get back on eBay. Nevermind... Do whatever makes you happy. I'm done. |
#208 (permalink) | |
Sorry If I came off in an innapproprate way. Its not an idiotic move....we aren't talking about a huge difference between the two bars 25 to 27mm If I rember correctly. With that said any additional Roll-couple distribution to the front of this car would decrease potential handling, that is all I was trying to say
#209 (permalink) |
Louder than 4 F404-GE-400
Maybe i could help explain what Revy is trying to say. First, let me give you some perspective on where Revy is coming from. Revy comes from a world of racing. Racing is done on/at the limit. Tegrady, from your statements, it seems that you don't drive at the limit of the car. If you did drive at the limit of the car, you would have noticed that the stiffer front bar makes the car push (understeer) more causing it to be less balanced. At the limit of any car, the end of the car that has the stiffer suspension realitive to the weight it carries (roll-couple distribution) will lose traction first. So in a fwd car, the front end has more weight to carry than the rear. So the more you stiffen the front suspension, the sooner the car will lose traction at the front of the car. If you stiffen the rear suspension, the rear end will lose traction sooner, than it used to causing some oversteer.
If you dont drive at the limit, the stiffer front bar will cause the car to have better turn in which can make the car feel more balanced when it really isn't. If you want a front wheel drive car to have quantitatively (measureble) better handling, you need to increase the stiffness of the rear end relitive to the front. So when you add a stiffer rear bar AND a stiffer front bar, you haven't changed the balance in the stiffness of the suspension. Honda designs the Si to push (have understeer) from the factory even though honda knows that a car with more oversteer (to a point) will handle better and put up better numbers on the track. The reason that they do this is because most people can't drive their way out of a wet paper sac and because most people cant drive at the limit, a car that understeers is easier to save once it is pushed past the limits. I hope this helped a little. |
#210 (permalink) | |
Very well said. |
#211 (permalink) | |
Again, thanks and sorry if I rubbed anyone the wrong way. |
#214 (permalink) | |
#215 (permalink) |
All I am saying is that putting thsi bars on the cars that already have less valving in their dampers is/can be a less than ideal situation.
Dampers springs and sway bars, all tune the car in different parts of the turn. SO if you are way off on what you put on you could get a car pushes coming into the turn, then is loose mid way through and out of the turn. Dampers mainly adjust corner entry and exit, Sway bars effect mid corner adjustments....."Meaning if the car is having corner entry or exit problems you adjust the dampers, if it is having mid corner issues then you need to tweak your spring rates or anti-roll bar rates" "The dampers influence the performance of the car Much more then anti-roll bars.. Anti-roll bars really only influence the mid corner oversteer understeer balance, where as Dampers influence not only corner entry and exit oversteer/understeer balance, but also your acceleration and braking performance as well as contribute to the general stability of the car." Hope this helps a little |
#216 (permalink) | |
Agreed on most things... I tend to suggest to people that if they aren't going to be pushing the car to its limits, then "beefier" swaybars will help make everyday commutes or spirited drives a little more entertaining. In certain cases, they will make the car ride rougher, especially if only one wheel hits the bump, but for the most part, swaybars are an easy way to add some spring rate to a corner without resorting to springs. Anthony "Mario" Crea NNJR-SCCA |
#217 (permalink) |
I agree with 93. As someone that has gone from just some fun on the streets, to some one that enjoyed the limit more and wanted to get into racing, I can see where both Revy and 93 are coming from. When i put a sway bar kit on my 94 GSR, It was the "best" suspension mod i (thought) put on the car because it made for a bigger change in feel than the Koni Reds and Eibach Pros i put on. But, after i got more confident with this set up and began to raise the limits of driving, i found out that the car pushed more with the thicker front aftermarket sway bar than the stock set up did. Up and until the limit however, i felt that the car was more "fun" to drive.
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/9328-si-front-rear-sways-ex-sedan.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-19-2008 10:44 PM | |
| Help me with my rear sway bar 2006 CSX - Page 2 - Acura CSX Forums | This thread | Refback | 01-14-2008 10:38 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-11-2008 05:15 PM | |
| Dumb Laws | C2i0v0i1c | Water Cooler | 58 | 10-03-2008 09:27 AM |
| EX Sedan 60/40 Split rear seats | 8civic8 | Civic Coupe And Sedan | 7 | 05-03-2006 08:57 AM |
| 2006 Civic Summary from Temple of VTEC | shoptb | Driving Experience | 4 | 01-11-2006 02:40 AM |
| 2006 Civic sedan rear window | clm10k | Civic Coupe And Sedan | 5 | 01-07-2006 03:23 PM |
