Old 05-03-2008, 04:40 PM   #41 (permalink)
FastTimesAtFGHigh's Avatar
http://jdmfg2.wordpress.com
From Eibach's website directly...
"Though with special progressive characteristic of the Pro-Kit, the damper is challenged more and usually makes it wear out faster."
FastTimesAtFGHigh is offline   Reply With Quote
Old 05-04-2008, 04:45 AM   #42 (permalink)
Holland's Avatar
Holland
The rear shocks will blow with in 200-1000 miles.. you wont feel it cause you drive it everyday...With the pro kits on stock springs i got 800 miles.. the the left rear shock was leaking. the fronts are fine but anyone who has a HFP kit will notice the rear shocks are 1" shorter.. thats for a reason... When you cut the bomp stops on the Pro Kit or any other aftermarket spring set up you will realize it will make the shock piston/shaft contact the top of the body and will distroy any stock rear shock in a matter of days.. I ran the HFP shocks with pro kit springs and loved it.. then swithed to the Progress spring and was in love.. then went with a progress rear swaybar, SPC rear and K-Mac front camber kits and mugen a arm bushings...with HighRev1's camber and a my own toe settings (1/8 out) ..well it was awsome.. So much so that I had lap times close to a evo around streets of willow... and I was on stock tires... the switched to Forglines on BFG R1's 245/40 17 front and 225/45 17 Rears...wit a little more ofset... and well it was crazy with only 200WHP...
Holland is offline   Reply With Quote
Old 05-04-2008, 09:19 AM   #43 (permalink)
CatScratched's Avatar
Wes
^^ yer givin me too many ideas!
CatScratched is offline   Reply With Quote
Old 05-04-2008, 09:54 AM   #44 (permalink)
ortivt6's Avatar
Ant
^^I have had the sportlines on my HFP shocks for 3weeks... 2 days ago we took my front suspension out to trim down the bump stops, since I didnt do them when I first got the suspension... there was NO leaks or any damage cause by the sportlines after 3 weeks of use...
Now am just waiting for eibach to send me the 2 new sleeves for the back, so I be able to trim down the back bump stop...
ortivt6 is offline   Reply With Quote
Old 05-04-2008, 09:57 AM   #45 (permalink)
ortivt6's Avatar
Ant
Also eibach requires u to trim 40mm, which is 1.7inches... I didnt feel that was right and only did 1.4inches to still have enough bump stop in case I hit a big bump or dip... and ever since then my car drives SOOO MUCH BETTER!!! It feels completly like stock when I hit bumps... But in turns it feels like a race car...
Now I can actually feel when I hit a big bump the back hitting the bump stop really hard... cant wait to trim it down too... then I be all set...
Old 05-04-2008, 01:36 PM   #46 (permalink)
Chyeaa
Tredd's Avatar
was planning on getting sportlines, but never heard of trimming this "bump stop", wat exactly do you do when you perform this?
Tredd is offline   Reply With Quote
Old 05-04-2008, 11:56 PM   #47 (permalink)
ortivt6's Avatar
Ant
^u have to do on any lowering springs to give the suspension more tavel... since when u lower ur car the shock has less travel... by cutting down on the bump stop the shock has more travel... so it performs better...
right before u installed the spring take out the bump stop from u suspension, measured the amount it tells u on the instructions and cut away... put it all back together with ur new springs and ur all done...
Old 05-05-2008, 03:01 AM   #48 (permalink)
Endo07si's Avatar
just a simple question for those who have lowered ther cars with just springs...do u now like your handling more or less than what it was stock? is their a really a big difference?
Endo07si is offline   Reply With Quote
Old 05-05-2008, 09:16 AM   #49 (permalink)
Christian
the handling is a little better but the problem is it bounces a little. I lowered mine with H&R Sports! i want to get rid of them and just get the hfp factory to be honest with you! Its going to suck driving people in the rear seats your gonna scrape every second!!!!
lopezchris86 is offline   Reply With Quote
Old 05-05-2008, 05:14 PM   #50 (permalink)
Endo07si's Avatar
lol well how much is the hfp lowering kit? is it the whole set of coilovers? cause i think those only lower you an inch whereas the stechs will do like 1.4 in the front and 1.3 in the back
Old 05-05-2008, 06:22 PM   #51 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Just ordered 2 sets of the hfp suspension.
Old 05-05-2008, 06:34 PM   #52 (permalink)
Wes
You can find the HFP suspension on eBay pretty cheap. Shipping can run you a little more.
You're right, it doesn't lower the car as much as other springs would. It is just enough to notice a small difference. And I still have no problem with scraping the undercarriage or, worse, the lip.
Old 05-05-2008, 07:53 PM   #53 (permalink)
mattsbobo's Avatar
Hal Jordan
Why 2 Ex?
Old 05-05-2008, 10:11 PM   #54 (permalink)
ortivt6's Avatar
Ant
The HFP is actually 0.8 drop... u can still fit 2 finger straight after the drop... where with s-techs or sportline u can only fit one finger straight...
Old 05-06-2008, 01:56 AM   #55 (permalink)
Endo07si's Avatar
noob question..wats the finger straight lol
Old 05-06-2008, 08:17 AM   #56 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Originally Posted by mattsbobo View Post
Why 2 Ex?
One for the fa5 and one for the fg2. My car (fg) and my wifes.
Old 05-06-2008, 11:15 AM   #57 (permalink)
ortivt6's Avatar
Ant
if u go between the fender and tire on my car u can put ur finger straight... meaning u dont have to bent ur finger to fit it in between the tire and fender like some people do... on the back u can fit a finger and still have a bit of space left...
Ima try to get some new pics of my drop since is been a month n it settle...
Old 07-01-2008, 05:41 AM   #58 (permalink)
Endo07si's Avatar
Ordering my stechs..ne1 have pics of their car lowered with stechs?
Old 07-01-2008, 07:42 AM   #59 (permalink)
mikehmike's Avatar
Michael
Most likely ordering the HFP suspension kit =)
mikehmike is offline   Reply With Quote
Old 07-02-2008, 10:57 PM   #60 (permalink)
Teach me how to take pics
maximus20895's Avatar
Max
I have no idea even though I have been thinking about it for a month or so...
P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS/ Auger Boot
TWM Cable/Base Bushings / StrutKing DP Cover / JDM Dipstick / Cleared Head/Tails /
My Car Build Thread - Amilia
maximus20895 is offline   Reply With Quote
Does Nitrous ruin your engine? Phresh Forced Induction And Nitrous 60 04-17-2008 12:48 PM
Best way ruin a pair of tires =] Repin da R18 Wheel And Tire Upgrades 6 11-02-2007 02:43 PM
W/ Amsoil will sychros still eventually mess up jmjohns9 Mechanical Problems & Technical Chat 11 07-18-2007 09:52 AM
Does waxing ruin the sealer? spocheld Detailing 15 10-10-2006 02:14 PM
Shifting from Park to Reverse (eventually to D)... ntwrkguy Mechanical Problems & Technical Chat 8 05-11-2006 03:18 PM
