Old 04-30-2008, 02:38 PM   #1 (permalink)
Your cookies, I haz dem
splew's Avatar
Andrew
Will Powerslot Plus work on R18 coupe?
So I'm a bit confused, I've seen people on here get Wilwood big brake kits for their cars even though wilwood says they only make them for the 01-05 civics and the 02-up acura rsx. So I wanted to get the powerslot plus brake kit (larger slotted rotors, factory caliper re-locators) form R18 coupe but powerslot says they don't make them for 06-up civics (just like wilwood) but they do make them for the 02-up acura rsx (non type-s) and the 01-05 civic (just like wilwood). I noticed that the people who got the wilwood dynalite kit got the one intended for the rsx and it worked fine, so I'm thinking that the same should be true for the powerslot plus. What do you guys think? Has anyone else tried it?
splew is offline   Reply With Quote
Old 04-30-2008, 07:34 PM   #2 (permalink)
Derek
they do make it for the 06+ civic. check out z1auto.com they got it on there. but your gonna need new rims to fit it.
KameraBoy is online now   Reply With Quote
Old 04-30-2008, 07:37 PM   #3 (permalink)
splew's Avatar
Andrew
Thats the Si kit I was wondering if the RSX (non type-s) kit would fit
Old 05-01-2008, 12:26 PM   #4 (permalink)
splew's Avatar
Andrew
Anyone else?
Old 05-01-2008, 12:52 PM   #5 (permalink)
JeShUa's Avatar
i can has lower?
Should bolt right up, although they don't want to say that because they have not done the research and do not want to get a bad rep for telling you bad information.
Old 05-01-2008, 04:08 PM   #6 (permalink)
splew's Avatar
Andrew
Ok, thanks a bunch!
Powerslot rotors backordered? unplugged Suspension and Brakes 1 03-21-2007 10:20 PM
Powerslot Big Brake Rotors! Z1 Performance Z1 Performance Inc 39 03-16-2007 10:29 AM
Powerslot Big Brake Rotors Installed! Z1 Performance Suspension and Brakes 47 11-03-2006 12:50 AM
