Old 04-29-2008, 08:18 PM   #1 (permalink)
HFP w/ SPC Camber Arms? Which hole to use?
I installed the HFP suspension on my 06 SI. Which holes should I use on the SPC arms to get -1 degrees of rear camber?
Brian
Fiji06SI is offline
Old 04-30-2008, 08:25 AM   #2 (permalink)
Juuken!
SiliconX's Avatar
Eric
Brian
I would probably use the first set of holes, closest to the wheel (the angled side of the bracket). That and maxing out the arm itself, should probably get you pretty damn close.
SiliconX is offline
Question regarding rear SPC camber arms SiliconX Suspension and Brakes 8 04-22-2008 10:08 PM
