Old 04-28-2008, 07:22 AM   #1 (permalink)
I am Godzilla U R Japan
gotsnodooks's Avatar
Russ
Lowering the Si
OK....I have a quick question.
I was attempting to lower my car this weekend and when I got the stock strut off and the DIY forgot to mention the minute detail of all the little ball bearings inside the strut...anyway...after spending an hour and a half picking all the bearings up and putting them back in I could not get the allen bolt with the nut on the top off. Is that thing reverse threaded and is there a trick to keep the top of the strut from spinning while trying to get the thing off?
Assassins do it from behind.
Mid Atlantic Crew #9
gotsnodooks is online now
Old 04-28-2008, 09:42 AM   #2 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
You need to break and loosen that bolt with the front strut on the car. And you DEFINATELY need to have a spring compressor, which I hope you do.
And lol at the ball bearings. I did the same thing the first time I took it apart.
SiliconX is offline
Old 04-28-2008, 11:56 AM   #3 (permalink)
Russ
^^ Good idea with leaving the strut in place....sometimes the obvious solution eludes me. Oh....and hearing you did the same with your bearings makes me not feel so bad...LOL
Old 04-28-2008, 03:28 PM   #4 (permalink)
IIIII's Avatar
Where are these bearings that you speak of? I just did my prokit install and did not see any bearings. :stumped:
And yes, leave the strut on the car when you loosen the bolt that keeps the top hat on. Loosen it until its about half way off.
IIIII is offline
Old 04-28-2008, 05:18 PM   #5 (permalink)
Louder than 4 F404-GE-400
Paul
You don't have to loosen the nut on the car. You need an offset wench with a hole in the top. Use the Allen wrench to keep the shaft from spinning an then loosen the nut. I've done it sitting on the ground with the suspension in my lap. Having a spring compressor makes the nut easier to turn and is way safer.
Sirbelch is offline
Old 04-28-2008, 05:19 PM   #6 (permalink)
Paul
I did the bearing thing too. He upper mount is sooooo easy to split.
Sirbelch is offline
Old 04-28-2008, 05:22 PM   #7 (permalink)
you don't know me
06blaksi's Avatar
yeah my bearings went all over the place as well. I CAREFULLY wrapped a microfiber towel around the shaft and held it with pliers while breaking the nut loose
http://i164.photobucket.com/albums/u6/2006nbpsi/sickcopy3bj5.jpg
06blaksi is offline
Old 04-29-2008, 06:26 AM   #8 (permalink)
Russ
Once you compress the springs enough you will see there are some ball bearings just under the top of the strut....there is a small plastic piece that keeps them in place but it is easy to knock that piece off and have the bearings go everywhere. It woud be nicer if they had used sealed bearings but then the Honda engineers wouldn't have anything to chuckle about when people like us take the strut off and have about a hundred little BB's fly out all over the ground.
Old 04-29-2008, 07:10 AM   #9 (permalink)
Johannes's Avatar
and yes only the si springs have these BB cuz the one on the ex of my gf doesn't have these BB's.....
to much of the good stuff baby HONDA CIVIC SI!!!
Johannes is offline
lowering question please help kene79 Suspension and Brakes 3 02-13-2008 03:33 PM
lowering the si??????????? BlackSI7969 Suspension and Brakes 19 02-11-2008 04:27 PM
Lowering my ride! Mitrofan Suspension and Brakes 8 07-10-2007 11:06 PM
Lowering an SI brewer3 Suspension and Brakes 4 03-20-2007 09:45 PM
LOwering the Si Lucky13 Suspension and Brakes 6 09-04-2006 08:59 PM
