Front Camber kit install......HELP PLEASE
Does anybody kno how to do this? I need to do it by t/m cuz im getting my car aligned tuesday....the instructions it came with are kind of confusing i'm just looking for a good explanation on how to do it, pictures would be nice...Thanks
8thcivic Sponsor
Its just a bolt replacment. Don't worry about where the cam is set to cause the alignment shop will set them for your camber setting.
"If you make sure the tab on the washer stays pointing out toward the hub, you can just rotate the bolt until it all slips in nicely flush with the strut. Now comes the tricky part. The nut is a lock nut that is hard to turn Access is limited to both sides because of limited space You can't allow the bolt to turn much because it has a cam. The tendency is to push the on nut, which causes the cam end head and washer to slip out of place. " ![]()
BUY MY CIVIC |
#4 (permalink) | |
| Full B&G Coilover and SPC front/rear camber kits Install | MonkeyConQueso | Suspension | 62 | 07-24-2008 07:33 AM |
| Camber Kit Install | baddceo | Civic SI | 4 | 11-18-2006 06:39 PM |
| Do you need a front camber kit too? | Marin | Suspension and Brakes | 4 | 08-08-2006 06:55 PM |
