Sportline Question - Help
I am installing my springs and want to know who installed the new crush sleeves and how easy it was? I believe I have a drill is that all I need to remove the old ones and be able to put the new ones in?
Also do you trim the bottom of the bump stop? -Jeff |
I got a mangina!
![]() Join Date: May 2007
Justin
i didnt, i used the stock ones, i didnt cut the rear bumpstops tho, its not really needed for the rear imo.
TW FG2 Sold.... |
Okay, so did you guys trim your bump stops in the front? I'm going to do both.
Did anybody install the crush sleeves? I want to do the install correctly and not have to correct any errors. The crush sleve is the little sleeve on the strut with the pin through it ortiv. The sportlines came with new sleeves. -Jeff |
I got a mangina!
Justin
honestly bro, i only trimmed the bumpstops in the front, i didnt do the rears because i didnt feel that it lowered the car enough to matter, but do as you wish, jmo tho.
TW FG2 Sold.... |
Kill Your Self Krew
no need to cut bumstop or use the sleeves. youll be fine
I got a mangina!
Justin
the issue your having is the fact that your not on coilovers, rather stock struts, which dont do well when compressed that much. your better off bottoming out on your bumpstops than your shock valves.
TW FG2 Sold.... |
#12 (permalink) |
Cut em
I installed mine and cut the rears and installed the new sleeve. Its easy just follow the directions that came in the kit. You only need to drill partially through the stock sleeve and it will come right off. Dont drill to far or you'll damage the shaft. Take it slow and you'll have no issues. Definantly worth the little extra time since youre doing the job you might as well do it right.
#13 (permalink) | ||
I got a mangina!
Justin
TW FG2 Sold.... Last edited by "Ridge"Racer; 04-27-2008 at 11:43 PM. |
#14 (permalink) |
For those of us that cant afford coilovers or to replace the struts right away, its as close to doing the job right as it gets. Take it easy, didnt mean to offend your infinent knowledge. Just trying to answer his question. In the instructions that came with my kit it said to trim 40mm off the bump stops which I believe is just over 1.5 inches not 3/8".
#15 (permalink) | |
I got a mangina!
Justin
TW FG2 Sold.... |
#16 (permalink) |
OK I guess I didnt specified it before... I got my sportlines USED... So I didnt get any instructions... so I just recetly found out bout cutting the bump stop... also am riding on HFP shocks, not OEM which are 1inch lower... The back is not the issues at all... its the front and only on big dips....
So does who have the instruction an could PM them to me... |
#17 (permalink) | |
Juuken!
Eibach recommended it, and they know far more about suspension than I do, so who am I to argue? It was really easy, took maybe 10 minutes.
#18 (permalink) | |
Juuken!
#19 (permalink) |
riding on skunk2's and they came with no instructions.. didn't cut the bumpstops and made no modifacations.. rides great.. when asked about the bumpstops i had a friend rolling on progress with stock bumpstops for almost a year and had no problems with struts leaking.. he thinks it's better to keep the bump stops in to prevent over compression on big bumps/dips and thinks thats why they lasted longer...had mine lowered for over 3 months and no issues.. bottomed out once on a huge dip and heard the bumpstops knock but still ok...
| Sportline on r18 | deotherhalf | Suspension and Brakes | 3 | 04-30-2008 07:13 PM |
| eibach sportline | xjosiahmicah | Suspension and Brakes | 5 | 10-16-2007 10:21 PM |
| Sportline springs | blackrose | Suspension and Brakes | 2 | 08-14-2007 09:54 AM |
| S-tech or sportline? | xxbodkinxx | Suspension and Brakes | 11 | 07-23-2007 01:44 AM |
| yes.. sportline is on!!! | ahslimjim | Introduction & Pictures | 11 | 12-09-2006 01:58 PM |
