Old 04-28-2008, 11:03 AM   #21 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
Originally Posted by ortivt6 View Post
so u did this to urs and havent had any issues on big dips???
No.
Just rubbing on the front.
SiliconX is offline   Reply With Quote
Old 04-28-2008, 11:04 AM   #22 (permalink)
ortivt6's Avatar
Ant
^is that with the OEM wheels, or the 18's or both???
ortivt6 is offline   Reply With Quote
Old 04-28-2008, 11:05 AM   #23 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
Just with the 18s. And it's only rubbing on the wheelwell clip.
Old 04-28-2008, 11:37 AM   #24 (permalink)
ortivt6's Avatar
Ant
^good!!! I decided that ima keep the OEM wheels for good... especially since I have the tire monitor system and I love the SI wheels lots...
Old 04-28-2008, 03:12 PM   #25 (permalink)
ortivt6's Avatar
Ant
well I decided to call eibach and they quickly send me the instructions for installing the sportlines... And I found out in order to tell the differences between left and right front spring one of the spring has a different part number... well am glad I used that spring on the left side....
Also on the bump stop, ur right, u have to cut 40mm on the front bump stop.... it also requires to do the back... but am not doing simply because I have the HFP shocks and the back was only lower 0.3 after I installed the sportlines...
Old 04-28-2008, 03:46 PM   #26 (permalink)
I got a mangina!
"Ridge"Racer's Avatar
Justin
It will or should drop a little more up settling, i was roughly at about a 1.6 drop in the rear, whilst the stock drop for the hfp kit really only lowers by about .8 inches i believe. you should be a little lower in the rear, seems weird.
Join the ATL SQAD
"Ridge"Racer is offline   Reply With Quote
Old 04-28-2008, 03:48 PM   #27 (permalink)
I got a mangina!
Justin
same here man, thats one of the first things i loved about the Si, i might get flamed, but they really are the perfect stock wheel imo!
Join the ATL SQAD
Old 04-28-2008, 04:04 PM   #28 (permalink)
ortivt6's Avatar
Ant
^^goin from HFP To HFP w/sportline it lower 0.6 front and only 0.3... Now its 13inch from the center of the wheel to the fender front and back... Its actually an even drop all around...
Hopefully now Ima have to trim the bump stop and see how different it drives after...
Old 04-28-2008, 04:45 PM   #29 (permalink)
Jeff Ashton
I didn't check the part numbers on my springs as the instructions didn't state anything about this. I have no problmes with my ride at all. I cut 40mm off the front bump stops and left the rears alone. The car sits perfectly and I love the ride quality.
-Jeff
jashton is offline   Reply With Quote
Old 04-28-2008, 04:48 PM   #30 (permalink)
ortivt6's Avatar
Ant
Front Spring Right 4.3140F
Front Spring left 4.3240F
Rear Spring 4.3140R
basically the only spring that doesnt have a 1 on the part number 4.3140 is the one that goes on the driver side... which is 4.3240...
Old 04-29-2008, 01:44 PM   #31 (permalink)
i sent the bumpstop trimming instrcutions to ortivt6 hopefully he can host them since i can't at work
newsiguy is offline   Reply With Quote
Old 04-29-2008, 03:39 PM   #32 (permalink)
I got a mangina!
Justin
you dont have to look at part numbers, rather, match the direction the coils assuming your doing one side at a time, not to mention, they seat in the lower perch according to the spring you need so its a no brainer.
Join the ATL SQAD
Old 04-29-2008, 04:47 PM   #33 (permalink)
JBlackSi's Avatar
I installed the Pro-Kit springs on my car couples week ago. In the instructions, they said to cut the REAR bumpstops. I did it. Now, i have no problem with the rear but the front ones are buttoming on big bumps.
The problem is, the kit only comes with 2 new sleeves for the back, not the fronts.
JBlackSi is offline   Reply With Quote
Old 04-29-2008, 05:12 PM   #34 (permalink)
the fronts don't use sleeves they are different
Old 04-29-2008, 05:33 PM   #35 (permalink)
ortivt6's Avatar
Ant
Thats what I did since I didnt have the instruction... and I did it rite...
Old 04-29-2008, 05:34 PM   #36 (permalink)
ortivt6's Avatar
Ant
On the front ones u have to trim the OEM bump stop that u transfer over when u installed the spring...
Old 05-07-2008, 01:47 AM   #37 (permalink)
ek4
i been thinking about getting the sportline.i dont want no noise or creek.i would be useing my stock shocks.wat do you guys think
ek4 is offline   Reply With Quote
Old 05-07-2008, 11:02 AM   #38 (permalink)
ortivt6's Avatar
Ant
^ no noise on my sportlines...
Old 05-25-2008, 11:54 AM   #39 (permalink)
18 AND 1
sgtmorph's Avatar
Does anyone know exactly "WHY" they say to remove 40mm from the front and rear shocks??? I installed my Sportlines yesterday with no problems. I didn't cut the bumpstops on purpose. I could be totally wrong but, I figured leaving the bumpstops alone might slightly prolong the life of my shocks. If I'm wrong, please let me know.
I do know that, since the bumpstops don't continually rest on the shock body, that cutting or not cutting either way doesn't affect overall drop and handling. So WHY cut them???
I'll add that after 24 hours, I'm only an inch lower all around. About how long does it take Sportlines to FULLY settle???
THX
CAN YOU BEAT MY RECORD???
I GOT 13 SECONDS AND 100% EFFICIENCY RATING
WANT PROOF??? click here>>> http://i130.photobucket.com/albums/p...C280/fg034.jpg
TRY AND BEAT MY RECORD>>> http://www.ingenuitywelcome.com/game/
sgtmorph is offline   Reply With Quote
Old 05-25-2008, 12:22 PM   #40 (permalink)
I got a mangina!
Justin
its supposed to allow for more travel with the shaft being that there is less bump stop, they are there for a reason, if you dont cut them, the ride may be a little bumpier but thats about it, your drop will still be the same.
mine settled after a month, the drop is pretty nice. got pics?
Join the ATL SQAD
Sportline on r18 deotherhalf Suspension and Brakes 3 04-30-2008 08:13 PM
eibach sportline xjosiahmicah Suspension and Brakes 5 10-16-2007 11:21 PM
Sportline springs blackrose Suspension and Brakes 2 08-14-2007 10:54 AM
S-tech or sportline? xxbodkinxx Suspension and Brakes 11 07-23-2007 02:44 AM
yes.. sportline is on!!! ahslimjim Introduction & Pictures 11 12-09-2006 02:58 PM
