Old 04-27-2008, 05:29 AM   #21 (permalink)
harobmx87's Avatar
Sarandis
Originally Posted by ziwang55 View Post
im sorry but i dont get. why do u cut the springs? for bump stops? ??
not cutting the springs. i hope nobody on here has ever cut their springs =/
cutting the bumpstops so u get a little more travel out of your shocks before you hit the bump stop since you're dropped.
if you leave your bumpstops alone and lower the suspension, the shocks are now compressed a little more than they were with the stock springs. so every time u hit a dip or a bump or something, u hit that bumpstop and it rides like crap
harobmx87 is offline   Reply With Quote
Old 04-27-2008, 12:13 PM   #22 (permalink)
ortivt6's Avatar
Ant
^damn I have to do this to mines... any pics on how to do it??? Or instructions since I didnt get any with my use springs...
ortivt6 is offline   Reply With Quote
Old 04-27-2008, 12:45 PM   #23 (permalink)
ziwang55's Avatar
whats a bumpstop
ziwang55 is offline   Reply With Quote
Old 04-27-2008, 01:54 PM   #24 (permalink)
harobmx87's Avatar
Sarandis
i took this picture from silverciv06's DIY.
http://i56.photobucket.com/albums/g1...Picture023.jpg
the bumpstop is the little yellow-ish white thing on the shock shaft.
Old 04-27-2008, 04:48 PM   #25 (permalink)
ziwang55's Avatar
oh i get it
Old 04-27-2008, 07:06 PM   #26 (permalink)
IIIII's Avatar
im seeing pictures of sportlines and the prokits and the drop looks pretty much identical, whats up with that.
My prokit drop is definitely lower than advertised by Eibach.
IIIII is offline   Reply With Quote
Old 04-27-2008, 07:09 PM   #27 (permalink)
K20z3 Civic Si [PHONG]'s Avatar
Phong Nguyen
Im rolling on Sportlines and I commute 100 miles in a day and its been perfect to me
K20z3 Civic Si [PHONG] is offline   Reply With Quote
Old 04-27-2008, 08:34 PM   #28 (permalink)
Nathen's Avatar
Nathen
im on prokit... i <3 it
Nathen is offline   Reply With Quote
Old 04-27-2008, 08:37 PM   #29 (permalink)
ortivt6's Avatar
Ant
OK how much on the bump stop do u cut off if u have the sportlines??? and what about the back shock???
Old 04-27-2008, 09:30 PM   #30 (permalink)
Phong Nguyen
I dont really remember how much I cut off on mines but I think theres like 2 grooves in the middle of the bump stop. I think I cut it at the second groove. On the back you dont have to do anything to the shock.
Old 04-27-2008, 10:08 PM   #31 (permalink)
Ainokea_Si's Avatar
Tony
i got the neuspeeds sports and I love them.
Ainokea_Si is offline   Reply With Quote
Old 04-27-2008, 11:06 PM   #32 (permalink)
damn man i couldn't get it scanned at work last week i will do it tomorrow for sure
newsiguy is offline   Reply With Quote
Old 04-28-2008, 10:59 AM   #33 (permalink)
ortivt6's Avatar
Ant
^ Just let me know when u send it...
Old 04-28-2008, 03:13 PM   #34 (permalink)
ortivt6's Avatar
Ant
well I decided to call eibach and they quickly send me the instructions for installing the sportlines... And I found out in order to tell the differences between left and right front spring one of the spring has a different part number... well am glad I used that spring on the left side....
Also on the bump stop, ur right, u have to cut 40mm on the front bump stop.... it also requires to do the back... but am not doing simply because I have the HFP shocks and the back was only lower 0.3 after I installed the sportlines...
Old 05-30-2008, 06:01 AM   #35 (permalink)
dannyd86's Avatar
Danny
I have a question. I myself am trying to decide between the sportlines and the prokits.
Now, I am going to be using the stock shocks until they blow. Hopefully Koni will come out with the yellows. If not, some Tokico HPs.
So the question is, will installing aftermarket shocks like these lower the ride height even more? I think I read that somewhere.
If this is the case, then ill get the prokit and then get shocks for the perfect height. In the same manner, I would think that the sportlines would be too low for me if they went any lower then the do with the stock shocks.
dannyd86 is offline   Reply With Quote
Old 05-30-2008, 10:17 AM   #36 (permalink)
ortivt6's Avatar
Ant
^Hey I use to lived in homestead (florida city)...
why dont u just get the HFP suspension which comes with both springs and shocks... they are almost like the prokits in height... and if u get a set of 18in wheels u be all good...
Old 05-30-2008, 03:21 PM   #37 (permalink)
dannyd86's Avatar
Danny
haha...
Ehh, not low enough for my liking. I think I'm just gonna do the sportlines. I was a little concerned about which ones to go with, but I guess if I don't like the drop, when I get some koni yellows (praying) haha, i'll put the pro-kits on.
Old 05-30-2008, 04:50 PM   #38 (permalink)
ortivt6's Avatar
Ant
|^well for references... if u have an si FA5 with oem wheels measure from the ground to the fender:
Sportlines 24 1/2 Front and 25 1/4 Back...
Prokits 24 3/4 Front and 25 1/2 Back...
HFP 25 1/2 Front 25 1/2 Back...
this would give u an idea of the drop...
Old 05-30-2008, 04:51 PM   #39 (permalink)
ortivt6's Avatar
Ant
Both HFP and Prokits have the same drop in the back... an on sportlines its only 1/4 lower in the back... so must of the drop is in the front...
Old 05-30-2008, 04:53 PM   #40 (permalink)
dannyd86's Avatar
Danny
Have an FG2 but thank.. Sportlines it is..
Recommend HFP suspension kit or eibach pro kit homeboyv Suspension and Brakes 55 03-25-2008 10:52 PM
Question on Eibach Pro-Kit 08ASMSIdan Suspension and Brakes 0 02-16-2008 01:34 PM
Eibach pro kit help throwtheanchor Suspension and Brakes 18 09-24-2007 04:24 PM
Eibach Pro Kit Question CEMO757 Suspension and Brakes 11 06-21-2007 06:11 PM
