Old 04-20-2008, 10:17 PM   #1 (permalink)
Need Help Asap, Suspension Problems:(
Hey guys,
I installed my Neuspeed sport springs this weekend on my 08 civic si,
the springs are for the 06 model, I was told they are all compatible from 06-08,
Ever since the install the car looks and controls great, but there is one problem
I get a knocking sound when i slowly turn the from wheels, and also another knocking sound when I hit bumps going slow in the rear,
What is happing? and how can I fix it?????
Thanks alot guys I need your help
tatertots is offline   Reply With Quote
Old 04-20-2008, 10:39 PM   #2 (permalink)
The spring are not seated properly on the strut in the front. you'd have to take it off and make sure the springs are seated properly. There should be a notch where you need to make sure your spring "butts" up against...
shingles is offline   Reply With Quote
Old 04-20-2008, 10:48 PM   #3 (permalink)
I put the rubber sleeve that was on the stock spring then put the rubber pin in the hole on the shock, but i will double check that, what about for the rear?
Old 04-21-2008, 01:53 PM   #4 (permalink)
Bump
Does anyone no whats wrong ?
Old 04-21-2008, 02:30 PM   #5 (permalink)
When did you put the suspension on? Sometimes it takes a day or 2 of driving to knock the springs seated on the perch. Sometimes that doesn't work and you have to take it out and properly seat them. That goes for the rear too.
taffysi is offline   Reply With Quote
Old 04-21-2008, 04:16 PM   #6 (permalink)
Last Thursday...
Ill try to uninstall and reinstall them tomorrow, is it dangerous to the car to drive with them not seated properly??
Old 04-21-2008, 04:18 PM   #7 (permalink)
sdblurjdmsquad's Avatar
REAL FRIENDS> car clubs!
i had the same prob after i installed them on 2 si's
and after a week they stopped im assuming they bounced into place.
sdblurjdmsquad is offline   Reply With Quote
Old 04-22-2008, 08:37 AM   #8 (permalink)
What are the chances that they don't bounce back into place??
Old 04-22-2008, 08:54 AM   #9 (permalink)
dgaddis1's Avatar
just re-seat them, and make sure EVERYTHING is tight, double check everything, then check it all again
dgaddis1 is offline   Reply With Quote
Old 04-22-2008, 10:58 AM   #10 (permalink)
I'm going to do that tonight, Thanks guys Ill let you no what happens
need help asap Kourosh-F Detailing 4 04-01-2008 11:54 AM
need some suspension help ASAP Blue JDM Coupe1016 Suspension and Brakes 1 03-28-2008 12:31 AM
help ASAP! todda13 Mechanical Problems & Technical Chat 0 03-27-2008 01:08 PM
Suspension Squeaks...and Dealer Problems.... hamerad Mechanical Problems & Technical Chat 0 08-28-2007 01:35 PM
Help Asap!!! ominous8204 Water Cooler 8 04-27-2007 09:41 PM
