Old 06-14-2006, 01:46 AM   #1 (permalink)
How to lower 06 Sedan?
I want to lower my 06 Sedan about an inch. What do I need to do? I see that some have done lowering springs and some have done the HFP kit. If I go with springs is that all I need? Or do I need new shocks and stuff. Want to do it as economical as possible. Also if I lower one inch what size wheels and tires should I get 17 or 18?
Please help
yellowjersey is offline   Reply With Quote
Old 06-14-2006, 10:52 PM   #2 (permalink)
kenchan's Avatar
im probably going to do the HFP, but still waiting for TEIN to release a
sedan specific S-Tech.
if your spring rates are similar to stock (which i don't have lbs/in yet)
you won't *need* dampers, but recommended as the stroke is going
to be that much shorter.
for sedan, im thinking abour running 17x7's with probably 215/45/17's
with +42 to +45mm offset. if i run a/s tires, i might do 225/45/17's
as the shoulders are narrower than high perf tires.
(i run S03 and GS-D3's on my weekend cars)
Old 06-15-2006, 10:24 AM   #3 (permalink)
peliROJO's Avatar
bumb. maybe somebody can help you, yellowjersey. Sounds like you need to do a lot of research, unless the above comments make sense to you. :) I believe you are looking for a "Guide to lowering" or something. I would start by reading all the articles found with this search.
http://www.google.com/search?hl=en&l...on&btnG=Search
peliROJO is offline   Reply With Quote
Civic SI Sedan Comes To America - Chicago Auto Show Debut webby Honda Industry News 11 04-19-2008 10:24 PM
7th Gen versus 8th Gen Civic Sedan iVTEC Civic Coupe And Sedan 4 08-15-2007 09:19 PM
Sedan or Coupe?? psylenc2k Civic Coupe And Sedan 52 06-27-2006 06:39 PM
New Civic Si Sedan Dirty Bird 15 Civic SI 35 04-12-2006 12:55 AM
Sedan handling iwu Civic Coupe And Sedan 2 10-07-2005 05:36 PM
