Old 04-07-2008, 02:00 PM   #1 (permalink)
todd_tampabay's Avatar
Todd
Exclamation Good Suspension Upgrade
All these parts i found on Battle Endless Performance
Honda Civic 06+ Rear Sway Bar
Honda Civic 06+ V-Type Strut Bar
Honda civic 06+ skunk2 rear camber kit
Honda Civic 06+ H-Brace Bar
and some lowering springs say 1inch front 1.2 back
would this be a complete suspension, handling and cornering upgrade or is there more? And is there a front anty sway bar?
Please fill me in not very knowledgeble about suspension, i hope i spelled that right :P
todd_tampabay is offline   Reply With Quote
Old 04-07-2008, 02:28 PM   #2 (permalink)
TeamBadger's Avatar
Dont get caught up too much on braces, they honestly don't do much if anything at all.
Remember that a huge part of the suspension upgrades are your dampers (shocks) , and a good set of sticky tires.
TeamBadger is offline   Reply With Quote
Old 04-07-2008, 02:34 PM   #3 (permalink)
SoCal07Si's Avatar
Just call me Daddy
front camber kit
upgraded shocks/struts
coil-overs instead of springs and struts and shocks would be "the best"
Depends on ur plans for the car
SoCal07Si is offline   Reply With Quote
Old 04-07-2008, 02:50 PM   #4 (permalink)
Todd
for a cheap begining i dont wanna spend 2 grand on coil overs do you think my list would make a good impact on stability and comfort, and is there front anti_sway bars
Old 04-07-2008, 02:55 PM   #5 (permalink)
Sounds like you should get the HFP suspension. Lowers an inch, improves handling, dampers and springs designed for your car. I have them and they handle great.
HFP Suspension $500 ish
Front and Rear Camber Kit $250-$300
Rear Sway Bar $150
I only have the HFP suspension and camber kit but am planning on the sway bar later. If you haven't read the sticky thread about suspension I would recomend it. That is where I learned everything about our suspension and made my decisions.
Suspensions!!!
zumzumzoom is offline   Reply With Quote
Old 04-07-2008, 03:05 PM   #6 (permalink)
Supreme Pizza!
Izzy's Avatar
Originally Posted by SoCal07Si View Post
front camber kit
Actually, a spring/shock combo valved and matched correctly would probably fair better than most coilovers out now.
Old 04-07-2008, 03:06 PM   #7 (permalink)
SoCal07Si's Avatar
Just call me Daddy
unless you have glue on your tires, i wouldnt worry about a front sway. Front camber kit would be enough.
Other than that, ur list is ok
Old 04-08-2008, 12:41 PM   #8 (permalink)
Todd
allright so i want to lower the car lil bit and make keep the tires on the road when turning fast, so rear sway, front + back chamber, what does hfp suspension kit include? are you sure it lowers? ( so SI comes lowered?) and what about a strut bar?
Old 04-08-2008, 12:48 PM   #9 (permalink)
HFP includes front and rear springs and dampers. All the hardware needed to install it also. It lowers the car about an 1"
Old 04-08-2008, 12:50 PM   #10 (permalink)
SoCal07Si's Avatar
Just call me Daddy
Strut bar is cool. HFP is like an inch drop, at best. It is NOT standard on Si's. (they do not come lowered) I think its just springs. (edit: see above)
All I have is springs, dropped about 1.5 inches and -2.0 camber all the way around. Dunlop rubber too. I cant complain.
Old 04-08-2008, 12:53 PM   #11 (permalink)
Todd
can ya put up a side picture of your ride i wanna see what 1.5 drop looks like, might be too low for me but still curious, plus i bet it improves center of gravity more so its better handling,and less air resistance
btw look at the v strut bar on the post i have all the way up, sais improves stability, so maybe better traction while cornering but im not sure if someone knows a lil more about struts please indulge me...
Old 04-08-2008, 01:02 PM   #12 (permalink)
Supreme Pizza!
Izzy's Avatar
People argue that considering the way our car is built, where the a-pillars are basically at our strut towers, and the firewall being in the same area, that a strut bar is mostly unnecessary. It will "feel" better, but it really won't make much of a difference in speed in corners.
HFP is shocks and struts and is slightly below or at 1".
Old 04-08-2008, 01:09 PM   #13 (permalink)
SoCal07Si's Avatar
Just call me Daddy
Strut bar is gonna help, a little. I will probably get one soon, but I know we're not missing out on too much without it. Like Izzy said, our a-pillars are in a good spot.
Tein S-techs
Old 04-08-2008, 01:11 PM   #14 (permalink)
Todd
that looks good
so 1 inch really wont make much of difference, but i did see someone on hondaautoparts.com or something like that say it lowers like 1.2 inches
( the HFP kit that is)
Old 04-08-2008, 01:13 PM   #15 (permalink)
Supreme Pizza!
Izzy's Avatar
I've seen a few HFP-dropped cars, and I personally think it looks better than "slammed" cars. The body shape of the car doesn't look good so low to me, IMHO.
Also, you're getting the security that the shocks are valved to match the springs correctly.
Old 04-08-2008, 01:14 PM   #16 (permalink)
Todd
Honda Civic 06+ Rear Lower Tie Bar $59.99
what the heck is this, is this like a brace or what?
Old 04-08-2008, 01:18 PM   #17 (permalink)
SoCal07Si's Avatar
Just call me Daddy
It replaces ur stock unit. Its not supposed to flex like the stock one will.
Old 04-08-2008, 01:18 PM   #18 (permalink)
-j-
Rear Sway Bar $150
Suspensions!!!
How much more bumpy is it ridewise? Is it about the same as stock? I'm going that route if it is.
-j- is offline   Reply With Quote
Old 04-08-2008, 01:23 PM   #19 (permalink)
Todd
would the hfp's work better with other springs(tein or something) than the stock would? cause i could get the hfp setup and just change the springs to get a lil better lowering rate, what ya think?
Old 04-08-2008, 01:42 PM   #20 (permalink)
ameuba10's Avatar
its hard to beat hfp suspension. like izzy said, its made for your car and id say its one of my favorite mods. comes with everything you would need, i dont think you should waste money on different springs. i really doubt itll do much but hurt it. other springs would probly just lower it a hair more if anything. plus the hfp's are pretty stiff as is
ameuba10 is offline   Reply With Quote
1999ish Integra Type R suspension vs. HFP suspension Illinoisone Suspension and Brakes 3 02-09-2008 10:05 PM
My Official Suspension Upgrade Info and Pics Thread Cookstar Suspension and Brakes 69 09-27-2007 11:38 PM
Suspension Upgrade! ** PICS ** CNUco2007 Suspension and Brakes 31 07-23-2007 06:38 PM
Hybrid Suspension Upgrade from Si Bun707 Civic Hybrid 6 06-13-2007 10:45 PM
Suspension Upgrade for DX/LX/EX with stock rims dallas_mike Suspension and Brakes 3 02-18-2007 02:51 AM
