#22 (permalink) |
I am SURE Skunk will help you, they really are geat over there!!!!
But one immediate solution is to Drill out the sleeve in the below picture, just enough to get that indent out and remove the sleeve from the stock shocks. As you probably don't have the sleeve that goes in between the two stock rear bushings. That stock sleeve is then narrow enough to hold the lower washer in place. So install would be Lower washer>Sleeve>Lower bushing>install>upper bushing>upper washer...That will solve your problems Enjoy Them
#23 (permalink) |
****update***
Well, I had my shop manager look at the install and from what he saw is that I was NOT missing anything, but the washers you see should have been installed under the car and not in the trunk. So with that fixed, the car sits fine and is now as firm as the front.
Sorry for the mis-understanding. |
#32 (permalink) |
You can adjust the rear with the sleeve still in place. What I did was place a floor jack on the control arm to have pressure with the spring and one of the rings, then loosen the top one and from there you should be able to move both rings freely. When you think you have the height you want, then lower the car.
#35 (permalink) |
Looks great man. I have a NHBP FA5 (2007) as well, but I just have the Eibach Sportline spring kit installed for now, which lowered it 1.3" F/R and it looks good, though not quite as good as your look. Plus, my stock suspension can't handle the bottoming out and "pops" a bit when I go over road bumps, but it's better than stock by far. Your S2 coilovers came with springs though, right? So my Eibach's would be worthless with this set, correct, or could I use them and sell the S2 springs as brand new?
#36 (permalink) | |
| 06+ Civic Skunk2 Pro-C Coilovers | CorSport | CorSport | 37 | 10-30-2008 08:23 PM |
| Skunk2 Pro-S Coilovers : Pictures and Installation with Review | sctuned.com | Suspension and Brakes | 70 | 07-09-2008 12:01 AM |
| Skunk2 Pro-C Coilovers test review on FG2 | feichai | Suspension and Brakes | 97 | 04-21-2008 02:18 AM |
| Got pics of my new NHBP FA5 | CapnCrunch926 | Introduction & Pictures | 12 | 12-14-2007 10:32 PM |
| Sexy NHBP from Seattle -- Nude pics inside! | wookieloou | Introduction & Pictures | 20 | 06-14-2007 12:30 AM |
