Front camber options...
I want to get about -1.5 in the front camber. Has anyone done this yet? I know with my EP-3, I used some optional Honda front bolts (one on each side to replace) and it gave me about -1.7. That's about what I'm looking for. If there isn't that option, I take it, it's safe to assume SPC or Skunk2's camber bolts will do the the job? What's the max negitve degree you can go with on those camber bolts from SPC and skunk2? Anyone know?
EDIT: I found that Honda does have oem camber bolts like they had for the EP3. I'm going to buy two of these from Honda on Monday...hopefully they have them in stock. Item number 19 Honda Automotive Parts ![]() Last edited by 02SilverSiHB; 03-29-2008 at 05:11 PM. |
There's people on here who got around -2.0 degrees using 2 camber bolts on each side in the front. Both the SPC and ingalls (Skunk2 doesn't make bolts for the front) is gonna give you around the same amount of camber is basically from those two it's personal preference. Personally I'd go with SPC.
8thcivic Sponsor
-.8 degrees is all you can get with the stock slip bolts.
BUY MY CIVIC |
#8 (permalink) | |
2007 Taffeta White Si Coupe
good site to find parts! |
#13 (permalink) |
I had this issue and others have claimed to have experienced this issue as well: some shops have issues getting the full range of negative camber adjustment from bolts on certain cars because of the way different driving conditions affect the parts of any given car. Just be aware of that and don't blame the bolt if this happens to you. I have the Ingall's bolts but all my shop could muster was -1.4 in the front - the bolts are supposed to go all the to -2.0 negative camber, so you can see there's -.6 degrees of travel that have disappeared as a result of...Pittsburgh roads?
![]() So, just be aware that your particular car MAY not be adjustable to -2.0 - it's not the bolts, it's your car's suspension and any shop worth their marbles should explain this to you. If they do, they aren't giving you a line of crapola. |
| Front Lip Options.... | HTOWN | Inside and Out | 4 | 07-19-2007 10:38 PM |
| what are best options for camber in rear? | LadyEmily | Suspension and Brakes | 17 | 06-21-2007 10:56 AM |
| Front grille options? | 06RREX | Inside and Out | 50 | 06-11-2007 04:48 PM |
| Front grille ~ Options?? | Torredo | Inside and Out | 2 | 11-17-2006 10:44 AM |
