Old 03-24-2008, 05:44 PM   #1 (permalink)
Subframe bolts - torque spec
I recently installed a Megan H-Brace. Occasionally, when braking or going over a bump, I get a "thunk" from the front of the car.
Does anyone know what the torque specs are for the 17mm subframe bolts?
Thanks
Mattz280 is offline   Reply With Quote
Old 03-24-2008, 06:07 PM   #2 (permalink)
Just checked the bolts.
The right subframe mount was pretty loose...definitely has loosened up since the install.
Torqued both 17mm bolts to 50 ftlbs. Still don't know if that is the correct spec...
Old 03-25-2008, 01:50 AM   #3 (permalink)
fg2!kid's Avatar
エリク eric
the torq for the 4 subframe bolts is 76lbf-ft for both the si and non si
your welcome
fg2!kid is offline   Reply With Quote
Old 03-25-2008, 07:35 PM   #4 (permalink)
Thanks!!!
What Are The Torque Specs Ft-lbs On The Bolts For The Engine Mounts? indus Mechanical Problems & Technical Chat 8 05-29-2008 01:48 AM
camber kit mounting bolt torque spec? 20civic07 Suspension and Brakes 12 04-18-2008 10:11 PM
how to do you do a compression test? and torque spec for spark plugs? 20civic07 Mechanical Problems & Technical Chat 4 03-13-2008 06:25 PM
ASR Subframe. Dessa_8837 Suspension and Brakes 2 03-23-2007 05:21 PM
bent subframe? drutoobored Mechanical Problems & Technical Chat 8 09-25-2006 10:14 PM
